Hey all,
since I bought my r34 way back in 2015 my car has always been running a rich.
It’s just an unopened 25det neo with the stock op6 turbo running just above 12psi , with a blitz front mount, turbo back exhaust with cat, apexi intake, oil cooler and a power fc tune.
the thing is the car runs without problems, but when you start revving it past 4500rpm hard and pretty much 12psi or close, it blows a lot of black smoke . So much so that I get soot everywhere on the back of my car and my bumper just above the exhaust is permanently stained .
I know running rich means it’s using more fuel then needed but is there more to it? I regularly service my car and change spark plugs every service too (bcpr6es -8).
There isn’t anything wrong with how the car runs. It actually runs perfect. No idle issues, no boost cuts, no pinging, no stuttering when climbing revs etc
Is there anything I can do to reduce the black smoke? Or is it just the way it is?
15 minutes ago, KiwiRS4T said:
What do your plugs look like when you change them?  Do you have a dyno chart of the afrs? Have you done a compression test?
The tips are always white, and the thread on the spark plug is black going down about 10mm. Don’t have the dyno sheet or compression test sheet. Never did it since I bought it. Also, the engine is at 246,000km
Reading plugs doesn't count for much unless you put fresh plugs in, do a wot pull and shut it down straight away.
I would put money on the tune is too rich in the boosted areas and lean/ok in the cruise areas
Get it tuned
Get it tuned
No point now. I’m gonna go max hp without unopened motor, for rb25 it’s about 450hp right?  New turbo with supporting mods such as fuel pump and reg, ffp, z32 afm injectors etc then I’ll even sack the power fc (because it has fuel cut) get it tuned with either a nistune or ems 6860 so I can get 2 step and anti lag.
15 minutes ago, IM-32-FK said:
reg, ffp, z32 afm
All of this is wrong.
16 minutes ago, IM-32-FK said:
sack the power fc
This is OK, but unnecessary, because
This is wrong
2 step and anti lag
Do you hate your driveline?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
