JC71 Posted May 26, 2020 Share Posted May 26, 2020 looking for a good clutch kit, (pressure plate, friction disc, bearing etc) for a 1998 ER34 25 GT skyline 2 door. has the stock 5 speed trans and rear end but engine has been swapped from the stock RB25DE to a RB25DET looking at this would it fit correctly? CLUTCHMAX STAGE 2 HD CLUTCH KIT for NISSAN SKYLINE JDM RB20DET RB25DE RB25DET https://www.ebay.com/itm/CLUTCHMAX-STAGE-2-HD-CLUTCH-KIT-for-NISSAN-SKYLINE-JDM-RB20DET-RB25DE-RB25DET/132706570255 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/ Share on other sites More sharing options...
JC71 Posted May 26, 2020 Author Share Posted May 26, 2020 (edited) er34 25gt skylines with neo engine have the same 5 speed trans as er34 gtt skylines with neo turbo engines? Edited May 26, 2020 by JC71 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931739 Share on other sites More sharing options...
Ben C34 Posted May 26, 2020 Share Posted May 26, 2020 How is that a good clutch? Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931742 Share on other sites More sharing options...
GTSBoy Posted May 26, 2020 Share Posted May 26, 2020 3 hours ago, JC71 said: er34 25gt skylines with neo engine have the same 5 speed trans as er34 gtt skylines with neo turbo engines? No. The NA box is a skinny little twig. The turbo box is huge. But you can put RB clutches on RBs of any stripe. By the way. That (eBay clutch) is the cheapest, nastiest looking thing I have ever seen. Spend a thousand $$. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931745 Share on other sites More sharing options...
Unzipped Composites Posted May 27, 2020 Share Posted May 27, 2020 3 hours ago, GTSBoy said: No. The NA box is a skinny little twig. The turbo box is huge. But you can put RB clutches on RBs of any stripe. As long as you have the push/pull variant correct. 2 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931755 Share on other sites More sharing options...
JC71 Posted May 27, 2020 Author Share Posted May 27, 2020 (edited) ok so the actual transmission (gear box, what ever you call it) is different from a RB25de 25gt NA model and a GTT RB25det turbo model, but any clutch will fit? so I can get a clutch kit that is listed for a GTT R34 and it will fit my trans? Edited May 27, 2020 by JC71 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931801 Share on other sites More sharing options...
JC71 Posted May 27, 2020 Author Share Posted May 27, 2020 (edited) or is this something to be considered with and best to swap entire trans at same time with a GTT trans? Edited May 27, 2020 by JC71 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931802 Share on other sites More sharing options...
JC71 Posted May 27, 2020 Author Share Posted May 27, 2020 like this one ? https://www.ebay.com/itm/132344218322?ViewItem=&item=132344218322 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931803 Share on other sites More sharing options...
JC71 Posted May 27, 2020 Author Share Posted May 27, 2020 so what are the differences between a RB25DE neo 5 speed and a RB25DET neo 5 speed? Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931808 Share on other sites More sharing options...
KiwiRS4T Posted May 27, 2020 Share Posted May 27, 2020 Strength. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931811 Share on other sites More sharing options...
GTSBoy Posted May 27, 2020 Share Posted May 27, 2020 On 5/27/2020 at 8:02 AM, GTSBoy said: But you can put RB clutches on RBs of any stripe. 21 hours ago, Unzipped Composites said: As long as you have the push/pull variant correct. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931814 Share on other sites More sharing options...
Unzipped Composites Posted May 28, 2020 Share Posted May 28, 2020 The R34 GT (non turbo) gearbox is essentially an RB20 gearbox, very weak and uses a push type clutch. The R34 GTT gearbox is exactly the same as an RB25DET gearbox, but uses a pull type clutch. If you are planning on changing to an R34 GTT gearbox/driveline at any point, then don't upgrade the clutch for your current gearbox - it won't be a direct swap without converting the GTT gearbox to a push type clutch. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931824 Share on other sites More sharing options...
KiwiRS4T Posted May 28, 2020 Share Posted May 28, 2020 3 hours ago, KiwiRS4T said: Strength. Sorry...and the 25DET has taller gear ratios. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7931826 Share on other sites More sharing options...
JC71 Posted June 4, 2020 Author Share Posted June 4, 2020 (edited) can any one define what parts and what makes it actually "stronger" or is it just simply less prone to break when abused? Edited June 4, 2020 by JC71 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7932326 Share on other sites More sharing options...
Ben C34 Posted June 4, 2020 Share Posted June 4, 2020 4 hours ago, JC71 said: can any one define what parts and what makes it actually "stronger" or is it just simply less prone to break when abused? It is heaps bigger. Gears, shafts, bearings. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7932336 Share on other sites More sharing options...
JC71 Posted June 9, 2020 Author Share Posted June 9, 2020 no matter which trans and therefore push or pull style I end up going with, what is anyone's experience with the brand SPEC for clutches? or one they can recommend for essential a "stage 1 clutch", looking for stock or a little better, do want to keep the pedal feel as soft and easy /close to stock feel. Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7932716 Share on other sites More sharing options...
Dil-Dog Posted June 9, 2020 Share Posted June 9, 2020 (edited) Ur small box from the gt is push type the big box from the Gtt is pull type, i used spec 6puck stage 3 and still very happy Edited June 9, 2020 by Dil-Dog Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7932719 Share on other sites More sharing options...
JC71 Posted June 9, 2020 Author Share Posted June 9, 2020 (edited) I'm sure that has solid engagement, but how's the pedal feel? do you have a lightened flywheel as well? Edited June 9, 2020 by JC71 Link to comment https://www.sau.com.au/forums/topic/480479-98-er34-skyline-25gt-clutch/#findComment-7932722 Share on other sites More sharing options...
