Hi Guys,
My brother in law and I are seriously considering getting a super cheap car to convert to a bit of a race car and entering into both the Cheap Car Challenge and the 24hrs of Lemons.
Lemons requires a car that costs < $1000 with all safety gear. Though there is some wiggle room on this.
CCC requires a car less than 2L with no forced induction, has to be 15y old (i think, i dont have the details in front of me).
Both require no engine mods, very basic suspension and brake upgrades and tyres.
We'd love an E36 BMW 318is. Super slow, but good chassis, weight distro and RWD.
We're hoping that we can hire a car trailer for the race weekends and tow behind the X5.
We're very early on in the piece and I'm just hoping for any opinions or stories or suggestions from you guys on anything to do with these races.
Thanks,
Christian
  • Like 1
Also, if anybody has an old car or a source of old race cars for sale, i'd love to see them. Or, if somebody has a car they'd like to donate, the car is going to be covered in SAU stickers.
Hey Prank, i have a bunch of old SAU stickers i can donate? They keep piling up from the contributor packs but I have no use for so many, have heaps of product stickers too if you want to go all out?
@fatz for 24hr Lemons challenge experience
I've personally been hankering for an Excel race car, with the added option of joining the Excel Cup races, small and cheap but FWD obv. but currently have no room or time, but looking forward to following your journey in this space!
  • Like 1
On 26/06/2020 at 4:55 PM, 260DET said:
For CCC a race Excel would be the go wouldn't it?
This definitely seems to be a favourite and theres lots available off the shelf for them.
Thanks mate, you've probably got enough to wrap the whole car!
Yeah the excels look great.
Anybody have any race car towing experience?
12 hours ago, PranK said:
Really? is it for sale? I'm assuming its either > 2L or turbo though?
It is for sale. 1k is a bit low for me though, but PM me if you're keen still. Happy to work something out. (i bought it for 6k, it's up for 5k).
It's a 2.0L Turbo. AWD, 5 Speed Manual.
Yeaaaaahh. So it's actually a 1.8 T (sigh...) be helpful if I knew what I had I suppose. :D
  • Haha 1
We’ve done a few 24hr of lemons events. Quick cars seem to be Integras and Pulsars. We had an old Celica for our first few races. Are now building a pulsar sss.
The car, cage, seat, brakes etc are going to come to about $9,000 to build. For us the car was $800, $1700 for the cage from agi, 500 for the seat, $1000 in brake pads and rotors, $500 for a new clutch, radiator, oil cooler, brake lines, harness, isolator, water pump, wheel bearings, bushings, springs, shocks, tyres and wheels. Plus all your oils and fluids.
I’m doing a build thread here
just remember the car is the cheapest part!
  • Like 2
Was just about to say the same as Tobz. Lemons is a cheap car but safety kit kills the budget.
On top of what he listed also have money for helmet, race suit etc depending on your tracks requirements.
Those items in spec and in date can add up also, specially with a team of 4 that are all different sizes.
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
