Hi there
Since I could not found any dedicated YouTuber with Rb25 so far, could you please help me to know how shall I got 500 whp goal in my r33 rb25 S1 in most efficient way ?
The car almost stock had below with not been Dyno or tunned yet:
Aem series 1 ( not installed yet )
Denso 550cc injectors and yellow jackets coils ( not installed yet )
Tomei elbow and fuel pressure regulator ( not installed yet )
Rb26 intake manifold ( not installed yet )
Aeromativ fuel pump 250 ( not installed yet )
Unbranded intercooler, Electric turbo boost controller, oil catch can and oil cooler
Bltiz blow off vulve and coils suspension
Catlic deleted with Jazma 4 inchs exhaust from half ( after Catlic )
Stock turbo
Is there anything shouldn't I install from the uninstalled parts or take out from installed parts ?
What do you think about the turbo ( with place to buy online) ?
Could you please suggest an etunner to help me out online ? Fyi http://www.evans-tuning.com/ could not supported me with AEM ecu ...
Thank you ?
Here is a Youtuber with a RB25 and over 500hp for you -
https://www.youtube.com/c/ClutchKickJunkies/videos
Have a look at the RB25 dyno results page and see what mods people are running to achieve your power goals -
  • Thanks 1
You're not going to do it with either of those. Injectors too small (and too old and shitty). Coils are shit. Upgrade to at least Splitfire, if not Yaris coils or R35 type coils.
Fuel pump is probably too small too.
  • Thanks 1
if 500whp (373kw) is truly your goal, your fuel choice also matters which can affect the turbo you choose to run.
As far as ECU's go, find one that your tuner will tune.
No one does or trusts online tunes for cars like these. They're pushed too hard and are too individual (even with same list of mods) to get anywhere close to trusting a tune from another car.
You'd need so much gear to convince yourself the tune is actually okay, to the point where you could just DIY the tune from that point.
  • Thanks 1
All fail whale items, please don't get any of them.
  • Like 3
  • Haha 1
  • Sad 1
Thanks the add is really helpful
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
