Good day guys, so I've finished doing a couple of mods on my RB20DET GTS-T, got a base map put on to my Nistune ECU and now unfortunately on idle it blows smoke out like crazy. It was smoking slightly before i pulled everything apart but I had thought it was the turbo seals hence why i replaced the turbo and a few other things.
4" Straight through exhaust doesn't help either I can imagine. Symptoms include on start up generally after about 15-20 seconds she starts to smoke white clouds, as she warms up the smoke intensifies. I've done a compression test this morning and the results followed from cam cover to firewall, 150/140/145/145/150/150 PSI.
I am leaning towards maybe the head gasket might have a crack in it or blown. But not enough evidence points towards this maybe?, No mixing of oil and water within the engine, I can say she's taking a bit of water not from the radiator but from the overflow tank.
I don't mind pulling off the head to do a head gasket but bloody annoying since i just put the dam thing back together and thought it was ready for a dyno tune.
I have ordered a leak down tester tool just waiting for that to come in, but welcome to any suggestions and theories or experience from you fellow members all input is appreciated cheers guys!
https://www.sau.com.au/forums/topic/480969-rb20det-really-smokey-on-idle/
You are losing coolant from your expansion tank, there's your clue right there.
9 minutes ago, JarodC said:
Goes to nowhere, just collects and drains if needed
is that catch can sealed? If so, that is not at all how that should be done and will cause damage.
Edited by TurboTapin
Yeah man it's sealed, bugger what would be the best solution to this? drill and tap a fitting for allowing the oil to drain out or change the catch can setup entirely? If not what damages can be caused and how so. I know it effects the crank case pressure
You have plugged up your engine. What you have done makes no sense and won't work. It is worse than the factory setup. It will cause smoking but as mentioned it really looks like a head gasket though.
You need to research how to plumb a catch can also while the car is apart
Your issue is not the oil drain, it's the fact that you basically sealed up your engine. I'm blown away you have not been sending dip sticks to the moon every time you start your car lol.
Do not start the car back up like that. If you want to keep your hoses setup the same way, replace your sealed air/oil seperator with a vented catch can (The ones with a filter on top). I prefer running an oem type setup with 2x sealed air/oil seperators.
  • Like 1
Man thank you so much! I took your advice and un-plumbed the catch can. Got it up to operating temperature and she didn't smoke! little bit but nothing like how she used too. Something I had just totally over looked. I topped up the coolant levels and ran the car for a while and coolant levels did not drop.
Mind you guys i haven't started the car or left it running for long at all. I had gotten it back from the tuner and he told he it was really smokey so I only bought it home and ran it for a little while. then left it in the garage. Today I let it warm up and cool down 3 times and checked for oil levels, mixture, coolant levels and so on. It seems to be promising i hope!
1 hour ago, Gojira34 said:
Just a thought about the smoke, could it be too much oil in turbo? Did you use restrictor in the feed line?
Yeah so its not a ball bearing turbo, Journal bearing turbo the fitting flange hole from where the turbo feed line connects to is about 3-3.5mm. Do you reckon that's fine?
So your tuner didn't spot the incredibly obvious catch can issue...... That's concerning.
Nah I only dropped off the vehicle to him to get a base map put onto the ECU for me to be able to start up the car and tow it in for paint. He was extremely busy as we had our Chrome Expression car event coming up. So he only had the car for about half a day before I towed it back home. Thank you for spotting out the mistake though hopefully it hasn't caused any major issues
  • Like 1
Hey mate, it really depends on size the turbo, not sure what yours is? But would think 3-5mm should be fine?!
most say -4an fittings, but I’m no mechanic, just what I’ve learned in forums.
just have good drain for the oil!
I Learnt hard way when I had my Vl RB30E+t, I just had some braided lines made up and bolted up to turbo! ? found out I needed a restrictor as was smoking like your photo!
anyway seems like it was the breather! Hope all good!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
