Shed clean out of various R32 GTST Coupe parts when stripping my race car
To many to list individually
Message me if interested
Pick up from Dapto NSW
Happy to ship at buyers expense
Can provide higher res pics of individual items if required
Cheers
Jason
Hi,
I would like to register my interest in;
  • The front window mirror inside panels (the plastic triangles).
  • The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.)
  • The air-con controller (provided it's working)
  • The seat belts (provided they're not frayed on the edges and are otherwise working)
  • The door window mechanism (provided it's working)
  • The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!)
If you come up with a $$ number that you'd like for that lot and an allowance to ship to SA, send me a PM and we can discuss.
cheers
Do you happen to have the seat belt retainers with the release button that the buckle lock into for the front seats?
54 minutes ago, GTSBoy said:
Hi,
cheers
No problems
Ill take some better pics of these items and send to you.
The front window mirror inside panels (the plastic triangles). No problems
The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.) Some scratches, and one of the mounting tabs broken on each indicator
The air-con controller (provided it's working) Not 100% sure, was disconnected when I bought the car.
The seat belts (provided they're not frayed on the edges and are otherwise working) No Frays and are working. Still have the passenger front in the car so its only the drivers front and both rear
The door window mechanism (provided it's working)Yes, working Bought to fix my drivers door, but just using passenger side switch to do both windows
The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!) Actuator is off RB25 turbo. I am now using the RB25 turbo with RB20 actuator
I think so, but didnt find them when doing the clean out. Ill have another look and let you know
  • Thanks 1
3 minutes ago, Jasoncauser said:
No problems
OK. Some changes to my list based on your feedback.
Indicators and wastegate actuator can drop off the list.
Air-con controller is a mystery proposition, so value is low. Still willing to risk it for a low enough price.
Driver's seatbelt is the main one I'd be interested in anyway, so the missing passenger's is OK.
Better pics of mirror panels, air-con controller, belts & window mech happily accepted.
No Problems, Will take some pics tonight.
1 minute ago, DaymoR32 said:
price on the front indicators?
They do have a few scratched and each one has a broken mounting tab.
give me a figure your happy with
Can send better pics if still interested
grab a few more pics and we'll go from there mate :)
That would be awesome if you could. Thanks.
  • 1 month later...
  • 10 months later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
