Shed clean out of various R32 GTST Coupe parts when stripping my race car
To many to list individually
Message me if interested
Pick up from Dapto NSW
Happy to ship at buyers expense
Can provide higher res pics of individual items if required
Cheers
Jason
Hi,
I would like to register my interest in;
  • The front window mirror inside panels (the plastic triangles).
  • The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.)
  • The air-con controller (provided it's working)
  • The seat belts (provided they're not frayed on the edges and are otherwise working)
  • The door window mechanism (provided it's working)
  • The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!)
If you come up with a $$ number that you'd like for that lot and an allowance to ship to SA, send me a PM and we can discuss.
cheers
Do you happen to have the seat belt retainers with the release button that the buckle lock into for the front seats?
54 minutes ago, GTSBoy said:
Hi,
cheers
No problems
Ill take some better pics of these items and send to you.
The front window mirror inside panels (the plastic triangles). No problems
The front indicators (provided they look pretty schmick - I don't need them if they've got chips/cracks etc.) Some scratches, and one of the mounting tabs broken on each indicator
The air-con controller (provided it's working) Not 100% sure, was disconnected when I bought the car.
The seat belts (provided they're not frayed on the edges and are otherwise working) No Frays and are working. Still have the passenger front in the car so its only the drivers front and both rear
The door window mechanism (provided it's working)Yes, working Bought to fix my drivers door, but just using passenger side switch to do both windows
The wastegate actuator (provided it's the stock RB20 10 psi unit and you're happy to keep it separated from the turbo!) Actuator is off RB25 turbo. I am now using the RB25 turbo with RB20 actuator
I think so, but didnt find them when doing the clean out. Ill have another look and let you know
  • Thanks 1
3 minutes ago, Jasoncauser said:
No problems
OK. Some changes to my list based on your feedback.
Indicators and wastegate actuator can drop off the list.
Air-con controller is a mystery proposition, so value is low. Still willing to risk it for a low enough price.
Driver's seatbelt is the main one I'd be interested in anyway, so the missing passenger's is OK.
Better pics of mirror panels, air-con controller, belts & window mech happily accepted.
No Problems, Will take some pics tonight.
1 minute ago, DaymoR32 said:
price on the front indicators?
They do have a few scratched and each one has a broken mounting tab.
give me a figure your happy with
Can send better pics if still interested
grab a few more pics and we'll go from there mate :)
That would be awesome if you could. Thanks.
  • 1 month later...
  • 10 months later...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
