Hello,
i am building a 350z drift missile with a florida imported Aristo 2jz GTE VVTI
My partner and I are trying to make it as "budget friendly" as possible while still retaining reliability and decent performance. We have a build list of new parts such as top mount manifold, turbo, gaskets, studs, oil pump, water pump etc etc.
So here is my question.... while the engine is out, we were planning on doing all the rotating assembly bearings and we were wondering If it would make sense that we pull the pistons out, clean it up, then replace all rings, then finally hone the cylinder bores with a honing pad/stone ourselves
I know that you shouldnt trouble the rings and bores if you are making good compression but if the engine is out... wouldnt it be a good idea? Is this too risky? i have seen a few people who have just got a hone and new rings and reused the stock rods and pistons but i would like to know if honing is something you can do your self and still achieve good results.
https://www.sau.com.au/forums/topic/481218-engine-rebuild-question/
EDIT: look i know that you  "CAN" do it your self and there is a few videos on youtube who show them selves at home with a drill and what not but i want to know if what they are doing is wrong and if they are just a set of bone heads. so yeah thats my question... lol ?
Yes, you can. The main issue is the drill speed too fast and it cuts too shallow a cross pattern. Something slow, eg cordless drill on low speed and a fast up/down motion, will work fine. Does't need long to work. Yes you should replace with new rings while out, and from there yes you should re-hone.
  • Like 1
If you pull it to pieces and the cylinder bores don't show much wear and the rings look good why touch that at all unless you are paying to do it right?
Actually, This ^.
Just because you pull it apart doesn't mean you automatically do anything. The only thing you have to do is carefully inspect and measure everything. If the bores are round and especially if there is no nasty lip at the top and especially especially if the hone marks are still visible, then doing anything to the bores is unjustified. You always assess what you have before deciding what you're going to do to it.
And then forget what you decided and mash the go button on that Nitto stroker kit.
  • Haha 1
2 hours ago, Unzipped Composites said:
Humorous reference to the natural tendency to completely blow the budget despite the intentions going into the build.
i was attempting my own humorous reference to accidentally purchasing hks h-beams (and a billet crank, which a workshop “lost”)
hey, each to their own...but, if i'd picked up a 2nd hand unknown engine, I had it apart, and was rebuilding it to ensure it was fresh and ready to last for me, there's no way i'd be sticking with the rings that were in it; i'd replace them along with bearings, water pump, timing belt, anything else that might " look fine". A set of rings is like 200 bucks, a hone does effectively nothing to the bore size, and pulling out and dismantling the engine is one Fkton of work, as anyone that's ever done it knows, so replace them while it's all apart, if budget isn't the utmost concern.
  • Thanks 1
On 25/09/2020 at 6:57 PM, Duncan said:
Are you putting a 2jz in a 350z for a cheap project?
4th time this week, thanks skid factory.
Adam lz has put more Jz engines into cars then the skid Factory
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
