Hello everyone! I just got back from Iraq I spent 2 years there. I was deployed with as a soldier and after that I started working as a private contractor. Long story short due to the troop withdrawal I was able to come home and pick up this R32 GTR from RHDSpecialty. It is a 1994 R32 GTR in crystal white with a Nismo 320km/h cluster, Nismo gauge and a Kakimoto exhaust (I recently swapped to a Tomei Expreme Ti). I have been wanting a project car for the longest time but never had the funds and now after working 12 hours 7 days a week for 1 year in Iraq I was able to buy this legendary machine. I plan to clean up the engine bay and take care of the small rust that normally will come with this 26 year old car. Any inputs on body work and rust prevention will be greatly appreciated it!
  • Like 3
Welcome,
That's a massive effort staying in Iraq for that long (I spent an 8months in Afghanistan years ago )
Looks pretty good at the moment. I don't have any experience with R32 bodywork but new suspension bushes and ball joints does make them a lot nicer to drive.
26 minutes ago, PranK said:
Not much better than a white R32 GTR. Well done.
I'm envious at how much space you have to work on the car!
:welcome:
Yeah, the space belongs to my dad. He has a retirement home on 45 acres of land and this warehouse to myself. I get to bond with the car and bond with my dad lol.
31 minutes ago, robbo_rb180 said:
Welcome,
I'll definitely keep note on that!
That's really tidy. Nice work. Treat it well and don't butcher it.
It looks like someone may have already done some work on the front suspension towers. That grey seam sealer around the tops is not original. Not saying it's a problem, just pointing it out.
  • Like 1
Chassis rails / sills, strut towers (as @GTSBoy  has pointed out), spare wheel well and passenger foot well (heater core) are the areas that I am aware of.
But there can be others depending on how far north the car spent most of its life.
  • Like 1
I was curious about the sealer also. all of the R32 I was looking at in the market did not have this so I'm curious also to see what was done when it all comes out.
Started to remove more things off the car. I spent a lot of time labeling all the connectors from the harness. No way in hell I was going to remember where every single connector plugs into. My dad also gave me this massive LED light for the warehouse. The warehouse that came with the retirement home he bought had poor lighting or did not work. Shines super bright and I was able to conduct work at night instead of racing until the sun came down.
  • 2 months later...
Life got in the way and I was finally able to come back to the R32. Man this is my first time ever fooling around with an engine removal and I'm breaking my engine removal virginity with an RB26 and holy f*ck this has been a pain in the ass! There is almost no room to do anything once you get to the plenum. Don't get me started with the top two tranny bolts. I was struggling horribly when it came to disconnecting the trans from the engine. After doing a little more research I realized this had a pull type clutch which required the throw out bearing to be released. So instead of releasing the throw out bearing I just released the fork instead.
  • Like 1
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
