I know it is outdated and there are plenty better options but more expensive. I recently was offered a deal on one for 500$ US dollars. My question is is it still worth to buy or hold off and save for a Haltech etc... I have an RB25det r33. If I hold off and save for a more expensive one, it'll be about 6 months give or take. Opinions?
https://www.sau.com.au/forums/topic/481733-apex-power-fc/
I think the PowerFC is fine for 90% of use cases, they have been running these engines properly for decades. As Josh said, you need to consider whether you can find a tuner familiar with it as that makes a big difference to the cost of tuning.
BTW if budget it an issue, keep in mind you will need a tune as well, cost 500-1000USD I guess
  • Like 2
https://www.sau.com.au/forums/topic/481733-apex-power-fc/#findComment-7945240
Absolutely agree with the above and should be fit for your purpose. The Power FC does give you a closer base to start with and less things need to be changed with the entire settings. I made over 500rwkw with one on the 32, but have since moved to the Elite 2500 and 2000 for the 2 single turbo 32 GTRs because of of things being used like wideband long term fuel trim, flex fuel, crank triggers, lots of extra engine sensors, engine protection strategies, can bus, etc.
For my 33 GTR, it's 330rwkw with a Power FC on low mounts on BP 98. No intention of more power or anything extra as mentioned above, so I will be staying on the Power FC for that car unless it fails.
So it's completely dependent on where you are aiming for modification wise really. If you intend to change lots of things down the track, an Elite would be worth waiting to get.
https://www.sau.com.au/forums/topic/481733-apex-power-fc/#findComment-7945259
Thanks for the input all. I don't plan to track her or anything. Just a daily drive. I'm shooting towards 400hp or so. My tuner can work with an apex but he recommended the Haltech platinum pro as the power fc is outdated he said. If apex is fine then I'll shoot for it then.
https://www.sau.com.au/forums/topic/481733-apex-power-fc/#findComment-7945280
I don't really see where the Haltech Platinum pro fits in these days with the elite series being out for about 5 years now. They are still a +/- $2k ECU new. Why would you when an Elite 2500 is $3k and a 2000 is about $2.5k ?  Both are far superior units to the Platinum Pro, so l don't see why a Platinum Pro would even be a consideration these days for the cost.
You get an Apexi for $500 - $1000, well it's hard to argue with it for the pure result of how they run the car isn't it ?
  • Like 2
https://www.sau.com.au/forums/topic/481733-apex-power-fc/#findComment-7945281
2 hours ago, joz said:
500 USD is a fair price. I'm not sure 500 USD can get you the full Nistune suite..... (Boards, cables, software license)
97% of car owners don't tune their own cars, so they wouldn't need to purchase the cable nor would they need to purchase the software.
Their preferred tuning shop would have the required cable and software. The shop license has no limits to the amount of Nistune it can tune.
https://www.sau.com.au/forums/topic/481733-apex-power-fc/#findComment-7945557
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
