Hi all,
I was hoping to get some ideas around deleting my antenna. I was getting rust around the antenna and I've never used the radio, so it's time to go!
My current thoughts are, clean up the rust, then either get a fabricator to weld in a metal plate for a factory finish, or to turn up a 50mm or so plate and either use an o-ring or seam sealer and bolt it down (similar to the common rear wiper delete kits).
Does anyone else have any ideas?
I've attached a photo of the rust situation.
https://www.sau.com.au/forums/topic/482017-antenna-delete/
33 minutes ago, niZmO_Man said:
There should be rubber plug thingies you can shove in there (after you've treated the rust). Not as good looking but a quick fix.
I did a bit of google-fu and couldn't find anything that would fit :(
Not being a round hole and being wider then the average wiper/antenna delete kit is making things hard.
https://www.sau.com.au/forums/topic/482017-antenna-delete/#findComment-7947771
It was my first thought but I just didn't know how much it was actually going to cost to get done.
But yes, I'm glad it's getting done properly. Should look good in a few years time when I finally get around to respraying the whole car lol.
https://www.sau.com.au/forums/topic/482017-antenna-delete/#findComment-7947800
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
