Hey all, just doing a +t conversion to my 25de R34 coupe. Just hoping someone might be able to help me out with what sort of kw/psi I would be able to push through the de without sending a rod to the moon.
I got a pretty stock kit off a DET with a few upgraded bits.
- All factory piping, intercooler, fuel rail, intake mani and throttle body, exhaust mani, 3" dump through to xforce exhaust.
- High-flowed factory turbo (20psi)
- Bosch 1000cc injectors
- Apexi FC with controller
I know a det can push 500rwhp without upgrading internals but cause of higher comp in the DE I don't know what I should be pushing out of it. Any help would be greatly appreciated, I would still like to daily it but have a fair bit of go if I put the foot down.
Thankyou all
https://www.sau.com.au/forums/topic/482143-rb25det-neo-power/
Well you have come to the right place! Welcome. Its been done to death previously on this forum. Use the search function.
Rb25 de+t ignition maps.. Boost
just plug that in to search function and choose from 10,000 hits
Edited by Rusty Nuts
additional information
As a serious answer
500rwhp (372kw) is not really that reasonable long term under heavy abuse (track work). I wouldn't push any stock RB that hard unless you're comfortably happy to rebuild/know a guy/have patience for it.
For the non turbo motor, I've heard similar numbers, but given it has higher comp I would just tune the car on 98 (or 93/91 as I suspect you're not Australian), and let knock be your guide.
E85 is good, but regular petrol does act like a bit of a sanity check.
2 hours ago, Kinkstaah said:
As a serious answer
Im in QLD Australia, the previous owner of the kit only ran it on e85 and it would still be my daily, ive just heard so many different numbers thrown around that I really don't know how far to go with a tune without blowing something up, I know I have the parts capable of pushing 400+ but I'm not sure if the internals could keep up with it.
That's because there are a wild amount of variables, so the actual number doesn't exist. How would it?
Im not after a specific number im just after a generally safe area where the internals won't be under so much pressure they break but also has some go if I wanted to put the foot down, I know it can make 400 but im not sure if 400 is safe because de comp is so high. I have the supporting power parts but if my internals can't do more than 350 on 10psi reliably then I don't know what I can put through it. Some people have said it'll do 400 on 20psi while others have said no more than 230 on 7psi. I never thrash my car as to me it's way too precious to me lol. I've just always had a large margin between what people say is good for it, that's why im hoping someone who has done it before would be able to tell me what I can and can't do with it cause I'm still learning all this sort of stuff and need a bit of help.
2 minutes ago, Rusty Nuts said:
I was serious Greg, trying to encourage self education before asking the universe.
I do appreciate the help, I just can't afford to buy a whole new engine if I go with a handful of people that say blast 50million psi through it. I've done some googling but again it's all very different for everyone and I'm not someone to flog the engine, it gets me to / from work and cruising through town on the weekends.
Sorry, I didn't mean to imply you weren't serious
That said
Searching the internet does lead you to believe 370kw is "safe, for years bro" and it is not always that case, or that simple. People's use cases vary so very drastically. Honestly NA+T I'd shoot for something like 240kw with a manual gearbox and highflow OEM looking turbo and be like yep go enjoy car.
However if you can't afford to live without the car/can't afford a rebuild/don't have another motor then Step 1, 2, 3, 4, and 5, is obtain a backup car/work towards an engine ready to go.
Have a backup plan. These are not cars you can drop off at your local ultratune and expect a broken motor to be replaced within a week.
Hence why I suggested the search on this forum, go back ten years and the crazy ideas were getting shot down. Go back three months and some new ideas and old were punted around. Its all in the archive here, plus you get to read GTSBoy's remarks all over again ( Warning: these remarks are intended to offend the "can I put an XR6 turbo on my N/A, will the gearbox handle 800hp crowd" )
Just remembered the member to check out is DatsunBanana he drives an R34de+t auto and is keen on the subject, also check out 666Dan's legendary thread.
How to turbo your N/A
By 666DAN, February 2, 2004 in Naturally Aspirated Performance
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
