On 29/04/2021 at 7:17 AM, BK said:
That won't cut it for a fuel pump. More like this on a heat sink.
100 Amp DC Solid State Relay with Heat Sink (windandsolar.com)
hey ben thanks again mate. attached a link of a 100amp one i found much like picture above. let me know if you approve im excited to give these a try. still learning way to much everyday
1 hour ago, BK said:
Yep that's it, the same as the Haltech or Crydom ones. That's a pretty good price too.
i wonder why they are priced so much differently look at these ones i found and no heat sink D1D100 Sensata/crydom, SSR, 100A, 100V (newark.com)
i dont understand how the heat sinks work. does it literally just pull heat from the relay as it warms up because of the shape of cooling fins much like some aftermarket diff covers?
Yep, purely heat dissipation. As Dose pipe said the heat sink is essential if PWM control is used. If just for on / off switching not so much.
  • Like 1
ok cool ill make sure too mount the haltech ones to some cooling fins and do it right. im done frying pumps. gotta slay some trees and finish up this mess, then we are gunna tune it up on e85
  • Like 1
23 hours ago, BK said:
So you are going to pulse width modulate pumps for speed control ?
this is how we wired it last night. one pump running all the time. other pump kicks in at 10psi. base fuel pressure is 45psi. nothing fancy yet. it pulled 580whp at 23 psi i was very happy with that. i havent got the built motor in there yet so this is as far as im going to push it for now. it feels extremely fast for now.
yes. i didnt even know what pwm was until you mentioned it bro. like i said i really am trying to learn all this stuff as i go im no where near on your level mate. the tuning, the pump setups, trigger kits, was all newish to me as im sure you know with the 100 questioned ive asked you over the year. i was just a very old school gtr owner that fixed my twin gtr as it broke back in the day.  this is my first shot at a hopefully reliableish single set up as well. i have been practicing my tig welding tho and getting pretty good,  im going to do all the piping on the bmw. just been busy with trees but taking a few days off hopefully soon to get some work done on the beamer, dyno vids uploaded, and hopefully some vids of smoking some hellcats and r35's.
  • Like 1
Well i know this thread got a little wanky, but i have to eat my foot on something and jump back to why i even started this thread. the whole problem was when we turned the set screw in to tighten down on the cherry sensor i must have ate my wheaties that morning because i crushed the sensor which is why it would read irratic. prp has since changed it to jam nuts one ach side of the bracket(prp wierdness) and once we tightened the jam nuts down we had to grind off the nuts on one side so it wouldnt rub on the stock crank pulley.  now made some serious power with the prp trigger and e85. doing another pull tonight on 25 psi
  • Like 3
6 minutes ago, Dose Pipe Sutututu said:
Sexual
oh mate. the building is literally falling apart every time we do a pull. wellness. very humbling unit i truely dont give a rats ass about jz's anymore. long live the forever oil starving/weakrod bolts/ head gasket/ bad oil pump RB26 who cares i love her let make some power see what a stocker can handle. going till we lift the head
  • Like 2
  • Haha 1
15 minutes ago, r32-25t said:
You may want to source another block to start the build with, they love to crack the decks with big power on stock internals
You sound experienced lol...
i have been building a motor the whole time the car build has been going on. just took some time with machinging as we were only using the stocker to fab everything up but now fak it gunna see waht it can do. it was a stock r33 motor in MINT condition. i bought 3500 dollars in sonic testing equipment and the block was unreal. i was considering sending it to herman an prp to confirm my test. but it was clear the block has seen no abuse the end bearings were still in great shape.  i couldnt care less if i broke the block ive read over a million threads about it im well aware good chap lol.  you can see it in about the middle of my build thread. the block is finally complete with a prp brace. Head is now ported and finished. just have to assemble it then we will install it end of month, so shouldnt have any cracking issues. im using a 6466 on the new engine. cheers
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
