On 29/04/2021 at 7:17 AM, BK said:
That won't cut it for a fuel pump. More like this on a heat sink.
100 Amp DC Solid State Relay with Heat Sink (windandsolar.com)
hey ben thanks again mate. attached a link of a 100amp one i found much like picture above. let me know if you approve im excited to give these a try. still learning way to much everyday
1 hour ago, BK said:
Yep that's it, the same as the Haltech or Crydom ones. That's a pretty good price too.
i wonder why they are priced so much differently look at these ones i found and no heat sink D1D100 Sensata/crydom, SSR, 100A, 100V (newark.com)
i dont understand how the heat sinks work. does it literally just pull heat from the relay as it warms up because of the shape of cooling fins much like some aftermarket diff covers?
Yep, purely heat dissipation. As Dose pipe said the heat sink is essential if PWM control is used. If just for on / off switching not so much.
  • Like 1
ok cool ill make sure too mount the haltech ones to some cooling fins and do it right. im done frying pumps. gotta slay some trees and finish up this mess, then we are gunna tune it up on e85
  • Like 1
23 hours ago, BK said:
So you are going to pulse width modulate pumps for speed control ?
this is how we wired it last night. one pump running all the time. other pump kicks in at 10psi. base fuel pressure is 45psi. nothing fancy yet. it pulled 580whp at 23 psi i was very happy with that. i havent got the built motor in there yet so this is as far as im going to push it for now. it feels extremely fast for now.
yes. i didnt even know what pwm was until you mentioned it bro. like i said i really am trying to learn all this stuff as i go im no where near on your level mate. the tuning, the pump setups, trigger kits, was all newish to me as im sure you know with the 100 questioned ive asked you over the year. i was just a very old school gtr owner that fixed my twin gtr as it broke back in the day.  this is my first shot at a hopefully reliableish single set up as well. i have been practicing my tig welding tho and getting pretty good,  im going to do all the piping on the bmw. just been busy with trees but taking a few days off hopefully soon to get some work done on the beamer, dyno vids uploaded, and hopefully some vids of smoking some hellcats and r35's.
  • Like 1
Well i know this thread got a little wanky, but i have to eat my foot on something and jump back to why i even started this thread. the whole problem was when we turned the set screw in to tighten down on the cherry sensor i must have ate my wheaties that morning because i crushed the sensor which is why it would read irratic. prp has since changed it to jam nuts one ach side of the bracket(prp wierdness) and once we tightened the jam nuts down we had to grind off the nuts on one side so it wouldnt rub on the stock crank pulley.  now made some serious power with the prp trigger and e85. doing another pull tonight on 25 psi
  • Like 3
6 minutes ago, Dose Pipe Sutututu said:
Sexual
oh mate. the building is literally falling apart every time we do a pull. wellness. very humbling unit i truely dont give a rats ass about jz's anymore. long live the forever oil starving/weakrod bolts/ head gasket/ bad oil pump RB26 who cares i love her let make some power see what a stocker can handle. going till we lift the head
  • Like 2
  • Haha 1
15 minutes ago, r32-25t said:
You may want to source another block to start the build with, they love to crack the decks with big power on stock internals
You sound experienced lol...
i have been building a motor the whole time the car build has been going on. just took some time with machinging as we were only using the stocker to fab everything up but now fak it gunna see waht it can do. it was a stock r33 motor in MINT condition. i bought 3500 dollars in sonic testing equipment and the block was unreal. i was considering sending it to herman an prp to confirm my test. but it was clear the block has seen no abuse the end bearings were still in great shape.  i couldnt care less if i broke the block ive read over a million threads about it im well aware good chap lol.  you can see it in about the middle of my build thread. the block is finally complete with a prp brace. Head is now ported and finished. just have to assemble it then we will install it end of month, so shouldnt have any cracking issues. im using a 6466 on the new engine. cheers
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
