7 hours ago, Nocsyn said:
Really dumb question but have you checked your timing? One random but crazy suggestion is could possibly the cat be clogged?  You replaced everything else....
good luck man.
I had a shop that specializes in imports and high end cars check the timing about 3 weeks ago. everything was all good. plus i had the timing belt and water pump replaced 3 years ago. Thanks for the help.
18 hours ago, Dose Pipe Sutututu said:
If the motor is cold, you should be able to blow into it, once it warms up it closes up.
When you unplug the O2 sensor does it idle better?
i unplugged the O2 sensor and absolutely nothing happened
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
