On 07/10/2021 at 7:52 AM, NCred02 said:
This car has been a great project. There's always something to do
I wish the opposite for mine, for me it's been a bad project and there's always something that is broken LOL
I dream of a car that can be used, doesn't break with nothing to do!
  • Like 1
On 08/10/2021 at 6:11 PM, niZmO_Man said:
Off topic but my BMW has been flawless, 75,000 km. B48 is a good engine :D :D
This is the reality, everyone says they're unreliable but at the track it's always the Nissans being spannered on and the BMWs are just carving up laps.
To be fair mine is a FWD hatch that I share with my mum. I wouldn't track it haha. But the point is you get into a modern performance car and drive instead of fixing 30 years old stuff. Especially now that 90's JDM cars and parts have shot up dramatically.
  • Like 1
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
