Fellas,
Have been doing more and more circuit work / time attack lately and a limiting factor is oil temps sky rocketing and not dropping off at all.
I have a basic setrab cooler mounted between the IC and Radiator however looking at going something similar to the below mounted offset on the passenger side with the biggest cooler (PWR or similar) that will fit and ducting to suit.
Any recommendations on alternatives or kits?
Cheers,
I've used setrab cores and found them good.
Directing air over the core will help massively as have found improvements of 5-10 degrees with ducts/shrouds.
if still daily/street car grab a sandwichplate/ oil block with a thermostat.
  • Like 1
Thats because your running 60's ya big unit !  Fast car, big horses, and Perth summer weather
What you posted is great option
Also you know mine as per below can assist there is you want
or get a 'Brake Duct Inlet' plastic to match your cooler or have Rob fab ally one also an inlet attach to the front bumper where air gap is
1538688976_OilCoolerinlet.thumb.jpg.a63b82b995d8b772a424c1b8dedd08c1.jpg299648594_OilCoolerducting.thumb.jpg.3aba4e9dc852e554937ef998aa6b691b.jpg
Edited by bcozican
  • Like 4
This would be contributing to most of your problem, move it so it's not sandwiched between heat and more heat.
Also get at least a 25 row cooler
Spoiler
Wow, that is an epic setup
  • Thanks 1
does the back of the cooler get peppered by stones?
My solution to this was to get some of the grille mesh that you can buy from Autobarn etc (although I actually used some metal gutter guard from Bunnings) and make a piece to fit on the back side of the oil cooler. I put it on the back side and bent it to cover the sides also, for paranoia's sake. The bend around made it easier to attach too, although I can't remember exactly how I attached it and I can't go look until I can go home, which will be....next year.
  • Like 1
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
