Hi everyone, just bought a r33 gtst with an rb25 NEO swap off marketplace with about 60k miles. My main issue is that the all cylinders are 5-10psi below spec. Highest is 150, lowest is 138.
Didn't get any service records from the previous owner. Any ideas as to what might be the issue?
The car idles and runs pretty rough and I've never pushed it past 4 psi, if that helps.
https://www.sau.com.au/forums/topic/483403-rb25-neo-not-holding-compression/
Most likely the only issue it has is how the test was done, those results are fine. You need plugs out, wide open throttle and well charged battery probably with a booster pack when you do every cylinder. Even then 9.2% variance is not an issue
  • Thanks 1
Yes. Agreed. Apart from one good data point I have (my Neo, tests on a trustworthy comp tester at ~170 psi on all 6) which shows that a healthy Neo can generate substantial cold comp pressure, there's nothing wrong with 140-150 psi.
As Duncan said, it could be a little worn, could be technique, could be a slightly low reading gauge, etc etc. 9% variation does suggest that some of it is wear, because clearly some have worn more than others.
  • Thanks 1
On 4/3/2022 at 12:49 PM, Dose Pipe Sutututu said:
Sounds fine to me, just send it with more boost to make up for the slightly below spec compression
What if the turbo is tapped out and it has nothing left to give? No point running a snail at half it’s capacity. It’s too big then. 🤷‍♂️
I think Johnny's next reply would be something about a 3.2 upgrade and Samsonas.
  • Like 1
I feel this car needs a BMW GS7D36SG DCT and yes a 3.2L.
Should go well with a street Garrett G40-900 in full twin scroll form.
  • Haha 1
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
