Hey All,
I have a R34 25GT thats experiencing high fuel consumption. I'm getting around 6-7 km/L on highway, so about 15L / 100 km. I used to get about 600+ km out of a full tank (65L) on highway so something just seems to be off. When I use the consult cable, I noticed my ignition timing has been retarded back to 5 at idle when the car has warmed up. I think it should be 15 or so. The car doesnt have any mods, and running stock ECU. Also, no codes come up when I read the ECU
Some of the stuff I've tried so far:
  • Change O2 Sensor
  • Clean AFM
  • Change Fuel Filter
  • Change coil packs
  • Change spark plugs
  • Check Fuel Pressure (seems fine according to workshop manual)
    • 41 PSI when fuel pump is primed but car is off
    • 38 PSI at idle
    • 46 PSI when vacuum hose pulled
  • Check VTC Solenoid - Clicks when 12v put across it, gave it a clean anyway and put it back in the car, but no change.
  • Check coolant temp sensor - seems to be working via Consult, and temperature guage on dash will rise up to just below middle
A few questions:
  • Can leaking fuel injectors / bad spray pattern affect timing?
  • I'm wondering if I may have skipped a tooth, but really not sure how possible that is.
I've added the logs here from nissan data scan in case someone wants to help take a look.
Really unsure what to do next, any help would be appreciated.
Thanks!
20224151332.log
Edited by _scott
https://www.sau.com.au/forums/topic/483613-poor-fuel-economy-on-rb25de/
low idle timing indicates inability of the ECU to control the idle speed down with the IACV, so it is reducing timing to get the speed down. This implies a vacuum leak, which shouldn't cause high fuel consumption (should make it run lean, if anything) but maybe the closed loop O2 control is going overboard.
Look for vac leaks with spray can of carby cleaner.
Also ponder if the air filter is too dirty. You made no mention of looking at it. Also, if that's not the cause, ponder if the cat has collapsed.
  • Like 1
It's possible that your air leak is not an external one but an internal one. Stuff like the cold start valve/intake air regulator as they get old can struggle to close properly and ends up bypassing a lot of air all the time. Your O2 sensor seems to be healthy and oscillating quite a lot. Makes me think I need to replace my O2 sensor if I'm honest, mine seems a bit lazier.
On 5/5/2022 at 3:05 PM, _scott said:
Ill take another look at all the vacuum lines. Maybe I missed something along the way.
It's not just lines. It's plenum gasket, inlet manifold gasket, TB gaskets, etc.
Whilst Joshua is correct that an internal vacuum leak is also possible, and an internal leak** could in fact result in the low idle ignition timing also, it won't cause the high fuel consumption. Well, it's even less likely to cause it than a normal vacuum leak from outside would, and even that doesn't seem like the normal result of a vac leak.
** What he really means is a dead or dirty/sticky IACV not being able to close enough to bring the idle down.
Or somewhere your intake plenum isn't flat and sucking in additional air, then your closed loop O2 control strategy is adding in more fuel to compensate for the false positive lean condition.
The above could apply to a pinched injector seal
The above above could also apply to an exhaust manifold leak, where additional air is being sucked in through a venturi effect and once again your o2 is reading baloney.
@GTSBoy  Makes sense. I'll give the carby cleaner method a try, I'm probably missing a leak somewhere. Any areas I shouldn't spray around? I assume near the spark plugs as it could ignite. I'll also take a look at the IACV and make sure it's clean. I did however clean that out fairly recently.
@Dose Pipe Sutututu I did take a look at exhaust leaks and there doesn't seem to be one. I sprayed soapy-water up near the exhaust manifold but didnt see any sign of leakage.
My valve cover gaskets are leaking, could that possibly cause a vacuum leak or nah?
Edited by _scott
Valve cover leaks are vacuum leaks in a MAF system. The degree to which that matters is likely pretty minor in practice unless you have a gaping hole that you've been ignoring but it does contribute a little.
@Dose Pipe Sutututu I dont have a smoke tester. Maybe I should go invest in one...
I tried checking my exhaust mainfold for leaks, seems fine. Took a look at my IACV, pretty clean, so doesnt seem to be an issue.
I also remove my exhaust and checked the cat, hasn't disintegrated and doesnt seem clogged.
Anybody have any idea what to check next?
ok, I bought a smoke machine thanks to  recommendations from @Dose Pipe Sutututu and found a leak instantly.
Looks like the gasket between the throttle body and intake is cracked and possibly letting air in/out.
Since shipping times are slow as hell from Japan, what would be the best way to repair this temporarily?
  • Like 1
On 09/05/2022 at 8:28 AM, Trex said:
You could try some permatex ultra grey, or ultra rubber.
Might get you out of a pinch. But there is no saving that long term.
This would be a great temporary, temporary permanent work around until your new gasket comes.
2x internet points to me! That's a bad looking crack. It could be responsible for your troubles, but it might not be severe enough. Look forward to your report back. This sort of stuff is great, because you have a problem that makes you start looking at the car, and you turn up all sorts of things that you really should fix, and you fix them all trying to solve the problem.
I order a fair amount of parts from Japan(Amayama) and it takes roughly 2-3 days to arrive in Quebec snail mail. 1 day if you pay extra.  If you're in Australia which is much closer, should take half that.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
