On 12/05/2022 at 9:51 AM, TurboTapin said:
I order a fair amount of parts from Japan(Amayama) and it takes roughly 2-3 days to arrive in Quebec snail mail. 1 day if you pay extra.  If you're in Australia which is much closer, should take half that.
As a long time customer, Amayama is pure shit at the moment for Australia. At least a 3-4 month wait if you are ordering multiple parts. Amayama have an office in Australia (Sydney), UAE and Japan and not all parts are stocked in Japan - some are US, some UAE. For Australia they don't specifically order and ship your parts to you from supply point either - they bulk order to Australia warehouse to keep shipping down which is why their supply to us sucks and takes ages. Having a local office here is actually a disadvantage because of this now - called the Sydney office yesterday as I have an order of nearly 4 months getting held up by still awaiting one part !
At least if you order genuine stuff from RHD, Nengun or JP car parts they exclusively source your parts within Japan and send direct to you from Japan.
  • Like 1
Amayama prices have been completely nuts for a while now. Almost anything if I can help it I order either through a local dealer if the part number is listed in the US parts catalog or from US-based dealers that will import/stock JP-only part numbers on a special order basis. They only use surface mail though so if they don't have something in stock it will be 3-4 months.
Damn 4 months is ridiculous. and I thought my 10 week wait in february took a long time.
I've noticed the only advantage with using Amayama is with large oversized items which would be costly using international shipping.
That's not even true either. I went to purchase a second set / pair of 32 outer sills which are over a metre long. This was going to be about $1250 -$1300 for them - and shipping with TNT / FedEX on top was going to be over $1400 !
When I got a set through RHDjapan it was about $550 with DHL...
You want fast oem, Ive gone back to these guys in Kyoto this year who I used to use years ago over Amayama - can't beat them for speed on oem parts but RHD is close. Both 100% reliable.
 https://jp-carparts.com/
Interestingly enough Amayama ears must of been burning as my last part is here this arvo and will ship entire order tomorrow from Sydney.
  • Like 1
On 5/12/2022 at 8:37 PM, BK said:
That's not even true either. I went to purchase a second set / pair of 32 outer sills which are over a metre long. This was going to be about $1250 -$1300 for them - and shipping with TNT / FedEX was going to be over $1400 !
When I got a set through RHDjapan it was about $550...
I suspect it's because you're in NT. local buyers in sydney can just choose pickup.
yeah RHD price is consistent. they offer consolidation free of charge and don't overcharge on shipping.
@BK @TurboTapinWas having similar frustrations with Amayama. I tried to order a while ago, but they quoted me $1500 to ship to Canada, and there was a 3.5 month lead time -_-
@GTSBoy @Dose Pipe Sutututu I fixed up the rubber boot, but still seeing the timing go way back to 5* on warm up. I hooked up my smoke machine again and I see it's still lightly leaking from that area. I may try some heat shielding tape to really seal off that area for now just to see if that makes any different.
Try closing up your IACV a bit, could be now there's too much air being bled back via the IACV and your factory ECU is shaving timing to keep the idle at target.
This is why I love DBW, you piss off the IACV and AAC air leaks.
If you're in Canada just go to your local Nissan dealer for parts. We're one of the few country's that seems to still be able to order JDM parts through dealer. Cheaper as well as there's no middle man.
I get small things that are cheap to ship from Amayama when I'm too lazy to drive over to the dealers.
Cheers.
Edited by TurboTapin
On 14/05/2022 at 8:51 AM, _scott said:
@Dose Pipe Sutututu I assume you mean by adjusting the idle screw?
Correct, try unplug the idle plugs, unplug the TPS and adjust the idle screw till it idles just a tad under the target RPM.
At the same time, you might as well check your base timing and also set your TPS.
(All the above is complete waste of time on an aftermarket ECU as you can offset the lot, except when there's too much air allowed through the IACV).
Yesterday I adjusted my base idle and set my TPS. Im still getting 5* ignition timing on warm up.
A few things I did notice yesterday tho was, when I put my key to On, my IACV starts buzzing. I cleaned it again and also captured a video of what its doing when it gets power. Is this normal for these things to buzz?
I also took some logs of my car while idling, I noticed occasionally in the software that all the guages would just end up going to 0 for a few milliseconds, and then return back to normal. Does this mean a short somewhere? Or is it likely that its just a software bug. First time I've ever seen this and I've used datascan quite a bit.
Ignition timing during engine warm-up is going to be a bit of a mess. The NEO IACV has two parts. One is the solenoid valve which is almost certainly never going to fail. The other is a coolant temperature controlled thermostat that meters more air when coolant temps are low but closes up as the coolant temps go up. This is the part that I'm worried about leaking excess air assuming you don't have any other vacuum leaks. If it doesn't close up properly the idle target will drop because the ECU sees coolant temp has reached a reasonable target but the actual thermostat isn't closing up properly and that's causing it to have to yank the timing out to get there. Maybe with hot enough coolant it finally closes up enough to have sane timing values but still low side of what you should be seeing.
Also, if you see the ECU connection dropping out I would make sure your USB connection is good first and foremost. I've had a lot of issues like that due to a bad USB cable. Also verify the consult port is connected properly and there's no weirdness like loose pins or other damage to the connector. Then maybe check the ECU capacitors?
Edited by joshuaho96
On 5/15/2022 at 10:24 PM, _scott said:
Ahh, didnt think it may be a connection issue with the laptop, but that's probably right. I'll double check the connection next time.
Is there any way to figure out if the coolant thermostat on the iacv is working correctly?
1843510535_ScreenShot2022-05-15at11_12_46PM.thumb.png.fcc332c7a93c53a6fd7a8ccb0287a9f3.png
I don't know why but there is no mention of how to test the cold start valve on the AAC assembly. I would only look closer at the cold start portion if you have normal ignition timing once the car is warmed up but you see less timing when the engine is cold.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
