hey mates i think this will be an easy question for some but i just finished building another 26 and have always wondered what the purpose of the 3 10mm bolts that go from the head  to block are(2 at back of engine each corner, and one in the front on intake side side). are these crusual for sealing the water jacket ports on those corners or are they even necessary. there kind of a pain and i would leave them out if there not necessary. cheers interested to hear some thoughts on this.
On 18/05/2022 at 6:19 AM, Duncan said:
I've never put them back, and never had a head gasket issue (not that the race car runs big boost or power)
thanks yet again duncan. cheers
On 18/05/2022 at 6:57 PM, Rusty Nuts said:
I have ALWAYS put them back and never had a head gasket issue. Nissan do not put parts in for fun.
correct, on that note i was wondering if they are considered a "clamping force bolt" at all and more a less a holder bolt to ensure its lined up once all said and done? i was leaning towards them being kind of important as they are only on the corners with the larger water ports. to be dead honest i was almost positive mine was leaking without them. i pulled the head off had it decked yet again and replaced the headgasket with the 10mm bolts installed now all is well. that being said last time i put the head on i didnt clean the stud holes enough nor clean the faces enough so that was probably the issue for the blown headgasket first go around. most rb26 engines i see around here dont have them installed because engine builders just dont know about them not do the owners and doesnt seem to effect much. of course for me it may have because wierdness follows this cat around all the time. cheers
I suspect that Nissan think they need them to even out the clamping force, to make sure that it is high enough in those corners to grab the gasket. It is quite possible that people like Duncan get their experience of successful clamping without the extra bolts because of upgraded head studs providing more total clamping force and maybe the corners stay above Nissan's desired/minimum threshold even with the uneven distribution of force resulting from leaving the bolts out.
And maybe Nissan put them in because the is enough clamping force with the stock head studs without the extra bolts, but there's not enough safety margin. That's the difference between OEM and aftermarket/modifiers. OEMs have to comply with the hard won lessons on how much safety margin they have to have in all their specifications. Modifiers get half of their gains by using up all of the margin and don't care (or know) that they are now 1% away from failure instead of 30%.
  • Like 2
  • Thanks 1
Nissan Skyline R32 GT-R Workshop Manual (plmsdevelopments.com)
page en68 in my bnr32 manual labels the 3 bolts as "cylinder head bolts" so im sure they are considered a pretty important bolt. id say thats a wrap on this thread. there was no stubbornness on not using the bolts ill use them everytime, just was curious on the thoughts of others on the bolts. verdict - use the damn things as cheap insurance everytime. cheers
  • Like 1
On 22/05/2022 at 12:09 AM, BK said:
Visual reference on the 3 bolts for others wondering location, as just put the head on the white 32 today
thanks for the reference pictures ben. hope all is well good buddy. hope the gtr's arent sucking the wallet to bad these days like my car is lol....cheers mate
On 23/05/2022 at 10:59 PM, hardsteppa said:
I didn't use them after a head gasket once, and yes a weep started. I use them again now every time.
seems to me some people have had luck resealing without them when running lower horsepower/ have an extremely good mating surface on head and block and have very good block without cracks and good studs etc. that being said i have deemed them being extremely important and will never not use them for what its worth. i would highly recommend them being used, im surprised they actually didnt use larger bolts on all 3 corners. cheers. oh yeah if you have some little cracks on your block and want to add some insurance on the jb weld you already added, throw some block seal in there and you will be amazing how it can seal up a block semi reliably. i pulled my thermostat and did a few heat cycles with block seal and it instantly sealed my block up and ive been hitting 27psi since with a fresh thermostat in. cheers
The little 10mm bolts are holding for dear life. 30 psi on ethanol/meth injection and things are feeling fricken spicy now! I hope the boost gods are with me at this power level feels like my face is going to the back of my head now.
  • Like 1
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
