I find that the 370CCA NRMA 2383 batteries don't seem to last very long considering that most of the time the battery is isolated as the car only gets intermittent use. Any suggestions? Is there a good lithium option? Am I just imagining the short life or is 370CCA a bit small?
https://www.sau.com.au/forums/topic/483707-r32-gtr-battery-options/
I suggest the biggest Century battery that fits in the space. I can't remember exactly which one I put in there. I think it's the 430CCA one. I find Century more trustworthy than most other options available in Australia.
I also suggest that you either leave a solar panel charger on it, or a good float charger, if it is really left idle most of the time.
That might be the NS40ZX (410 CCA) which is not listed on Century's website any more. I've sent them a message to ask if its been discontinued. https://www.centurybatteries.com.au/products/car-batteries
The NS40Z is the 330CCA version, which is 'D' polarity (ie positive on the left, and you install it 'backwards') and small post. They still have the NS40ZLX MF ('C' polarity version @ 410 CCA).
There are a few web listings of the NS40ZX around so i'll see if i can find one.
Ended up getting a NS40ZLX after confirming the cables just reach by using an old NS40ZL from the Stagea. The bonnet is still well clear of the positive terminal, so only slightly ghetto.
Do what Gtsboy suggested though...keep the battery on a trickle charge.  I use an Oddyssey PC925MJT in my R33 and it also [these days] gets intermittent use.  But - so far - my battery has lasted 5 years cos its always hooked up to a solar panel and PR1210L regulator.  I also wired in a blocking diode to stop night time discharge.  I have a plug I use under the car and so every time I park it, I plug the solar lead into the car.  The panel doesn't have to be a big one, a 5 to 10 watt unit will easily do the job.  I use the same type of setup on my bikes, my excavator, and my mini dumper.  The dumper has a Lister 2 cylinder diesel motor which has no alternator or generator so the solar setup was almost essential.
Before I did this, I was going through batteries every 12 to 18 months.
I have a battery isolator as well, but a battery just sitting there slowly fades away, esp. in the cooler months.
What happens is the battery plates calcify, this then stops the chemical reaction needed for effective charging and recharging.
By trickle charging you stop plate calcification.
  • Like 1
I would recommend Panasonic OEM style batteries for any Nissan. Decent prices and three year warranty for private use.
Something like this would fit a R32 and provide decent CCA, the R version should be right polarity too: https://www.everybattery.com.au/online/product/n-60b24rje/
Edited by junkie
Spelling fail
  • Like 1
On 04/06/2022 at 8:21 AM, blind_elk said:
Autobarn has a Supercharge brand, which has a NS40 equiv (MF40B20L), at 390 CCA.
Two things:
1. I have had two Supercharge batteries in the GT-R and they have not lasted very long
2. Is there a rule of thumb regarding how long a battery should be on a trickle charger? Maybe, possibly related to point #1.
I've bought a ctek mxs 5.0 (mentioned by BK above, $129 delivered from ebay) and the instruction video says you can leave it connected for extended periods of time. So, refer to vendor doco, but as trident says seems like any good one should be able to be left connected indefinitely.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
