Has anybody successfully worked out how to have an aftermarket gear position indicator for an auto in a stagea?
With the Link dash installation almost complete were having issues getting the gear position to show on dash unit, as the factory dash uses 2 seperate signal types between the box and the ECU, as in it receives a square wave signal and transmits a sine wave or vice versa, so it's not reading and allowing the dash panel to show .
It will also be making it potentially worse being that the trans is a manualised valve body and being Jatco 4th gear is electrically selected as well as the lock-up for converter, so they are switched seperate
https://www.sau.com.au/forums/topic/483731-gear-indicator-display/
On 6/6/2022 at 8:05 PM, GTSBoy said:
Just do it calculated off of vehicle speed vs RPM.
We can potentially do that, but what about indication for neutral, reverse,park and converter lock up? And would also like to avoid any more thousands in labour costs for calculating and calibration, am reaching out to Link and Aim(dash manufacturers) to see if they have a work around,but thought there may have been someone that's seen it done in a track,drift or drag car that has a Jatco box???
I can look into the wiring tomorrow and see where it picks up the signal if you want
  • Thanks 1
There are switches for those, no?
TC lockup could possibly be inferred from rpm vs speed also. If it sits dead bang on the relationship given by the gearing, then TC is locked up. If it is in the "band" available from TC slip around the gear ratio, then it is unlocked.
Yep there are 2 manual switches for 4th gear and lock up, so they're the easiest to solve I spose in comparison, just a bugger that the Link ecu and the Link dash can't bloody read the gear position by themselves, and seems that I'm always the damn guinea pig too, but that's my fault for wanting pretty /shiny things and jumping first....
I have replied in other thread, this is so easy to do and isn't thousands to setup by a competent workshop/tuner.
Its all in what is wired to ecu and in its setup so many people have no idea how to do it right.
Can't you snoop the TC lockup solenoid to determine this too?
Honestly have no idea with anything that has wires cos I tend to let the smoke out of them, so I leave that stuff to others and stick to mechanical things that I can see what they do and how.....
The 2 shift solenoids form a 2-bit number which describe the forward gears. But don't assume, 0 is first first gear, and 3 is 4th gear. I think from memory b00 is actually 3rd.  The ECU loom also has wires which are digital states for when central shifter is in reverse, neutral or the forward gears.
Coupled with some microcontroller logic (or lucky you if your ECU is modern and has some flexible inbuilt programmable logic), you could determine what gear is currently active, and drive an LED digit display.
Forget the speed vs rpm method for an auto.
P.S.
From one of my micro programs the solenoid combos are as follow (LSB being solenoid 1)
b00 : 3rd gear
b10 : 2nd
b01 : 4th
b11 : 1st
P.S.
b00 : 3rd gear
b10 : 2nd
b01 : 4th
b11 : 1st
Cheers, will look into this
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
