Peeps... next SAU - Vic meeting as follows
Date: Tuesday - 17/08
Venue: Whitehorse Hotel
5 Burwood Rd, Hawthorn
Time: 7.30pm
Agenda:
Another update on things, an important announcement of the SAU - Vic club setup.
You i'll have to come along if you wanna know what its going to be about :)
If you have any other Agenda items, please post here.
Or PM ADZMAX or myself as we'll look after it.
See everyone then
https://www.sau.com.au/forums/topic/48403-sau-2nd-general-meeting-1708/
  • Replies 60
Damn! another one I can't make it to... I'm going to be in a hospital bed that night :D (nothing too serious). It sounds like the club is starting to get off the ground, should be good if it's all ready for the biggest summer season of cruises (and photos!).
Would like to come down. My car may not be ready by then. And I have no Skyline yarns to tell...yet!
But if SAUVIC membership and CAMS will be discussed I would like to hear about it.
Q. I have the skylinesaustralia membership .pdf I got from www.saunsw.com - does that membership give the same as what SAUVic will be offering?
Q. Will the SAUVic club have a simmilar "RULES and CONSTITUTION" or use the NSW already existing rules?
your two questions were addressed at the last General Meeting one month ago. :P
1) We are doing our own member form. SAU Nsw is totally separate to the show going on down here at this stage
2) And the constitution is done
- ash
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
