I am looking at a new one piece driveshaft for my R32 GTR. I am wondering if anyone knows any pros and cons of carbon fibre vs aluminium. Car will be street driven but is built for drag and roll racing. I am leaning towards aluminium as it is plenty strong (metro r32 gtr ran well into the 6s with one). Will not loose fray like carbon can if scratched and is cheaper to buy.
I know carbon Fibre has better shock loading capabilities.
any other points from either camp?
https://www.sau.com.au/forums/topic/484145-carbon-vs-aluminium-driveshafts/
By better shock loading do you mean it transmits more shock loads? Pretty sure it's more torsionally rigid no?
26 minutes ago, Murray_Calavera said:
I think he is referring to the shock load that occurs on launch.
Big sticky drag radials, engine on limiter/2 step, then bam, huge shock load through the drivetrain on launch.
Yes. That’s I was talking about. Carbon fibre is meant be gentler on the drivetrain around it by absorbing some of the shock. Aluminium much less so.
On 10/21/2022 at 1:04 PM, GTSBoy said:
Porsche 928 torque tube in an SA Sports Sedan thingo was reputed to build up something like 7 complete twists at grid flag and clutch drop.
I find that so hard to believe. I would believe "7 times as much twist" as others, but not even one complete twist. Would love more info on that.
Anyway my vote is get something from Aus, usd exchange rate and shipping is crazy.
GJ drivelines can do alluminium tailshafts, give them a call.
  • Like 1
It might have been even worse, like 11 times. The maths is relatively easy. Solid shaft of X diameter. Y torque applied at launch, with a little extra effort put in for the fact that it's a dynamic situation, not just statically loaded. The core shaft in the torque tube winds up, then unwinds as the torque is fully delivered to the diff end. I'll see if I can find the post on it. I think it was on PF, like, 15-20 years ago.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
