what i will also say is, your wheel alignment is in .1's of a millimeter. A flex of 0.5 of a millimeter translates through to your wheel alignment, so, even if bracing makes 0.3 difference to flexing, it's ' working'.
also just saw in one of the old Best Motoring (s)exposes on the R34 Z-tune, that they go to the extent of reinforcing the strut towers with dry carbon, in addition to their Sydney Harbour bridge strutbrace, so would appear there's something worthwhile in bracing this area for handling performance.
On 12/15/2022 at 2:24 AM, hardsteppa said:
I use an Ultra-Racing one - its a 1piece design as opposed to the 3-piece design (which didn't give any noticeable change) that is more common. "difference" is hard to say but, when combined with these braces, forgotten what they're called
Yeah, did see a difference in how solid the front-end feels at highway speeds.
The top A-arm is towards the top of the strut tower and these arms do see alot of flex, as evidenced by the Cusco a-arm rubber bushes flogged out within a short space of time (hack tip, you can replace these with Superpro R33 rear control arm bushes trimmed to suit) so, tying the towers together will reduce flex. Without hardcore equipment like a chassis-rig to measure body flex under load it's going to be guesswork but, I drive this car every day under all sorts of varying conditions and try to keep in mind what's real and what's placebo....I think a solid crossbrace helps.
Pretty sure that's called a fender brace? I bought one of these from Nagisa Auto but never got around to installing it. Makes me wonder if there will be noticeable effects then if you replace the strut tower with a higher tensile strength steel version like the Garage Yoshida strut towers.
2 hours ago, Robzilla32 said:
Lots of science here but I have had my hoon bars cerakoted so they will be reinstalled.
I am sure the coating will add to their strength.
It'll keep it from rusting, so surely in the long run that'll help things.
It would make a tiny difference, if you're going all out on a race track, but it makes a much bigger difference to people's wallets when they release it for the public to purchase.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
