Thanks for having me!
New to the forum- long-term Z32 owner, new R32 GT-R owner from Brisbane, Australia.
Currently searching for info regarding wheel/tyre fitment- purchased this old girl on Friday. She's clean for the price, but the wheel/tyre width is a huge problem.
18x10.5 +15 Enkei RPF1's
285/35R18 tyres
Wheels are in great condition, it'd be a real shame to replace them but they are causing major issues in the front of the car- they've worn through the inner guard liners and physically restrict the steering (can't turn to full-lock).
If you've run this size wheel, I want to hear from you! Can it be done with a smaller radius tyre, or am I up for replacing both the wheels and the tyres?
Cheers 🍻
  • Like 2
https://www.sau.com.au/forums/topic/484179-new-gt-r-owner-%F0%9F%91%8C/
Hi Sam, congrats on the purchase.
Unfortunately 18x10.5 don't fit properly on the front. You might get away with removing the guard liners and using undersized "stretched" tyres.
18x10 +15 to + 22 fit OK
The Enkies are not particularly strong wheels and you will find examples of broken ones as well. These days a GTR deserves quality wheels that fit properly.
  • Like 1
  • Thanks 1
Thanks so much @Duncan!
Was in two minds about trying a smaller diameter tyre VS new wheels/tyres, that advice confirms it 👌
16 hours ago, niZmO_Man said:
18x10 +20 is the max i'd go (it's what I'm running)
285/30 looks good and fits better than 275/35
285/35 is too big IMO
Thank you @niZmO_Man, appreciate your advice.
At the size you're running, do you have any issues with the tyre contacting the inner guard liners? Assuming you haven't had to roll or otherwise modify the front guards?
Guards rolled. My car is fairly low and it does occasionally rub on the front liner on full compression, although not as bad as 275/35. I also run like -2deg camber and about 6deg castor.
  • Like 1
21 minutes ago, Shoota_77 said:
I had one, terrible car!  The CVT felt like it was operated by the loosest rubber band ever made….
I second this! We're in the process of getting it ready for sale lol. Don't get me wrong, they're nice enough to drive when they're working. I’ve just had too many issues with Subaru's to want to add another to the list 😂
  • Haha 1
Update: picked up a set of 4x R32 GT-R wheels locally. Long-term, but not permanent solution. Tyres on them are shot and require replacing, but have MT's fitted to 2 of them (255/50R16).
Will be test fitting to check tyre size as I'm eyeing off a new set of Toyo Proxes R888R's (245/45R16). Once I pick up a new set of wheels for her, these will be stored for track use.
Edited by Sam_AusBNR32
Adding info
  • Like 1
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
