Yeah hard to be certain without having checked the configuration but it sounds exactly like the intake air temperature sensor is unplugged, which is an issue if air is based on a MAP sensor not the air flow meters....I would stay off boost if you don't know how it is set up as it is potentially an engine killer
Begs the question what intake air temperature are you running? Because for some models atleast (EG RB26 in an R32) it should be replaced with something less antiquated/faster responding.
  • Inlet Air Temp sensor (IAT) – From factory the GTR is fitted with an IAT sensor to the inlet manifold and this is supported by the G4+ plug-in. However for best results we recommend an alternative IAT sensor to be fitted to the intercooler pipe just prior to the plenum entrance.  This may use the existing IAT wiring or connect to the expansion connector of the ECU.
I got the oem inlet temp sensor
Yeah you can't run that if you're using speed density. It's the exact same part as the coolant temp sensor and is incredibly slow to react. In the OEM ECU all it's used for is to detect heat soak and enrich the mix as a result.
Why do you say that I cant use it when its been fine this whole summer on my new map with link ecu?
You can use it, you just shouldn't as Link state and djr81 posted up for you
It is electrically compatible but way too slow to react for proper tuning of quick load changes.
You aren't driving a cheap shitter of a car and an engine rebuild would be a substantial cost. $150 for the correct sensor is good value
  • Like 2
If you want the long explanation, you need a fast-reacting IAT because in alpha-N or speed density you want to be able to know roughly the temperature of the air in the cylinder the instant the intake valve closes. This feeds into the ideal gas law equation which is then used to estimate the air mass in grams in the cylinder. The reason why the stock ECU doesn't need to use a fast-reacting IAT is because air mass is not calculated but measured directly at the MAFs. So it doesn't matter what the IAT is downstream, you already know the air mass directly. This applies to any MAF-based system.
  • Like 1
I have researched a bit and came across a this "FAE 33166" https://www.autodoc.co.no/fae/2495306?gshp=1&gclid=Cj0KCQiA4uCcBhDdARIsAH5jyUkvDlPnJalva3nLNelUOFAsjmuzf8U95mQYbH0MUL_tlMm2kDCc6XkaAmHQEALw_wcB
Will this fit in the original location without modification and is it plug and play or do i have to re-tune the car with this new sensor?
The thread size is identical but as far as I can tell you will need a harness adapter. Keep in mind part of the reason why people relocate the IAT is that the stock position will heat soak so you will probably want an insulating washer on the IAT at least. Nissan deliberately put the IAT there because the goal of the original sensor was to detect heat soak and enrich the mixture in response.
Also, the "retune" will just be changing the temperature vs voltage calibration table in the tune.
I use the sensor mentioned on the Haltech Elite, they work well. Golebys and Platinum racing also sell them, but they are just the factory long reach metric M12 thread Hella sensor 6PT 009 109 141 or 041 from BMWs and Landrovers, so they are cheaper to buy from a non performance place. They use a 2 pin EV1 connector like the factory injectors.
In the factory location heat soak doesn't seem to be a problem with the Hella sensor as the sensor body is plastic, unlike the factory metal sensor which yeah as mentioned is no good when using VE tuning.
Ok, I had no idea I should change out the iat sensor at all... nor did my tuner mention it. So I should go for the Hella sensor https://www.autodoc.co.no/hella/937856 if I use the oem location? is there any adapters from oem to the hella sensor so i dont have to cut any wires? Can I "tune" in the new sensor myself or should I let my tuner do it?
You can definitely make an adapter, I just don't know that anyone has one readily available.
18 minutes ago, Dose Pipe Sutututu said:
That's what I did
47 minutes ago, Dose Pipe Sutututu said:
Looks better than OEM with the boot.
Premium.
Yeah I got my own connector with a straight boot on the blue 32 as most of the kits have a 90 boot, which isn't as nice as the wiring might need to be extended in some cases.
On the white 32 it got the GM sensor from Haltech as it comes with the Elite and because the old man is a tight arse, didn't want to buy another sensor he already had. To fit the GM sensor the plenum needed to be retapped to NPT and about 20mm cut off the temp sensor thread boss, as the GM sensor is much shorter and needs to be pushed further into the airstream.
  • Like 1
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
