35 minutes ago, damnonrs said:
i will hard wire it for now until my problems are resolved and get it dyno tuned again. i'm just worried about fuel temperature running the pump at 100%, is that a problem or its ok to just have it on full blast at all times
It's fine, main concern with a big pump is you overwhelm the pressure regulator but if you fit an aftermarket high flow one it shouldn't be a problem until you're really flowing a ton of fuel.
An 044 or 340 is generally not big enough to stuff around with a properly working stock fuel regulator, but his reg looks pretty suspect and need of replacement anyway.
so i spoke to my tuner, and he said he just changed the wiring that goes from the battery to the pump, the line in the fuel tank and the wiring in the fuel tank is still OEM at like 22 gauge or whatever it is. is that essential to upgrade or would that restrict the voltage?
The shorter the wiring run the less resistance there is but you'd have to actually measure the voltage drop to be sure. If you've confirmed that the fuel pump is running at 100% flow all the time then your problem is almost certainly related to the regulator then. Every other part of the system is running like it would be at full throttle.
  • 10 months later...
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
