17 minutes ago, Rezz said:
Is this for sale? 😋
zomfg @Rezz! How've you been Adam??
Haha sadly yes it's going up for sale, just tidying it up a bit and modding it ever so slightly so I can still drive it to SAU events.
Who's Adam? Hehe 😁All good mate, it's Justin.
Been good! And you?
The HCR32 is looking sweet by the way! Love the very neat Nav install.  I would love to get one but I'm at a crossroads right now and can't commit to another car.
Been good! And you?
Oh sorry Justin! I was racking my brain trying to remember names, not sure why I associated “Adam” with 7tune!
I’m good, been away from Skylines for over a decade, got family and kids now. Just getting back into owning a 32 but it’s a whole different world now… tax is higher and tech is better.
Same (except for the R32 bit), my son is saving for his first car which he hopes will be a Kouki V37 GT with the twin turbo 3.0L V6.... kids these days! My first car was a Renault 16 haha 😄
Sorry for the thread hijack
No worries. Wow V37 with the VR30DTT is an amazing first car. Mine was a 80’s Mitsubishi Colt that I saved up for! Both my kids are still under 4, but the older one has started helping me while wrenching on the cars.
Didn’t think I’d ever see CarPlay in an old as hell R32!
added a few spacers to the mounting bracket to make the unit sit flush with the shroud and gap free for a factory look.
usability is good. Originally thought I’d need to move the aircon controls down and make a custom bracket, but it seems the head unit is still usable and I can reach it fine in its normal position. On ya Nissan engineers for thinking about ergonomics of a touch screen 30 years ago!
  • Like 2
  • 3 weeks later...
OK so I just bidded $500 on an R33 GTS4 that no one seems to want. Waiting on a call from the agent to see if I won.
32 GTS4 is for sale. I can't deal with the temptation to mod it.
4 hours ago, r32-25t said:
Just modify it, it’s your car at the end of the day
you’ll definitely want to modify the 33 being na it’ll be slower then a wet week
100% I’ll hack into the 33. Strap a turbo onto the RB25DE and/or put the 25 head on a 30 block.
33 passed in cos the reserve was too high. I’ll try lowballing it again and negotiate. Aim is to have it landed and on the road for under 15k, then spend the same amount on top in mods.
To be Frank (always liked that name), I reckon this is a better idea. I'm an R32 man from day 1 and the really good surviving examples that are still in stock form should stay that way. Let ye conscience guide you my son 🙂
  • 2 months later...
On 30/04/2023 at 12:31 AM, funkymonkey said:
Lol at the rates these parts are selling for I might have a million sitting in storage.
looking specifically for an R32 GTS-4. The poor man’s GTR. I kinda have a soft spot for them and I don’t feel bad modding them. Plus they’re about 1/4th the price of a GTR of the same vintage and kms, but go 80% as fast. There’s heaps of aftermarket GTR bits that bolt on including drop in engine swaps if I decide to go for big power.
Altho Andrew probably won’t let me into GTR Festival with one lol
Find my old R32 GTS-4 "TURB06"  I put $50K+ into it - Although a RB20 it also had RB26 possibilities as per import VIN - lost track of it 15 years ago after selling for $11K in perfect condition...  😞 😞
  • Like 1
50 minutes ago, Roy said:
Haha just trying to put the car back together to sell it. On the lookout for a cheaper GTS4 that I don’t feel as bad about ripping into.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
