So, I wish I'd done an oil analysis before changing my turbos because my analysis shows elevated (53 ppm) levels of lead.
I don't have an analysis before this, so there is no trend. I'll do another change and analysis in 5k to establish a trend but I'm curious about whether this is just a sign of a steady decline? I have no knocks and oil pressure seems ok.  Is this something my engine can recover from or is it on borrowed time?
My mechanic did add some additive for stem seals in the last oil change which would be in this analysis. I'm not sure if that would affect anything.
Also, the oil in this analysis is the first oil change I did with the car so I have no idea how long it had been since the previous one. I was given a service history but I don't fully trust these.
I know we don't have heaps of info and I'm kinda freaking out a bit, maybe prematurely.
Find out how much lead is in that additive. Lead is normally a no-no, but seeing as it is an "additive" they might be able to get away with relatively low levels in their product, that could then turn up at the ppm level in the bulk oil.
I forgot to mention also that he cut the filter open and saw no glitter at all in there.
Yep, I'l give him a call shortly. Fingers crossed!
5 minutes ago, PranK said:
I'm reading that lead is likely from bearings. Can these be caught before it's too late or is it doomed already?
Well, yeah, there is a (very thin) layer of soft lead on the surface of bearing shells to provide that first "cushion" against physical contact. Just because it is wearing off doesn't actually mean that the engine is dying. Of course, it can mean that the engine is dying.
If the engine is making no noises and the oil pressure is (mostly, as in most of the time) fine, then it could just be suffering under particular conditions. That could be startup, or maybe at some point in the normal operation cycle - or maybe the Beemer engine suffers under long left hand bend (see, highway on ramp) and the pressure drops. You'd need to try to work out if any such thing is happening and then determine if you need a bigger oil pump, or an Accusump or something.
My engine has only an oil pressure switch from factory and I've installed an after market sensor that will alert me to pressure loss (https://www.sau.com.au/forums/topic/484431-my-bmw-335i/page/3/) . These engines can definitely feel long left/right handers which is why I added this sensor.
There are no other symptoms at all. No strange noises (in fact after the turbos were replaced the mechanic made a note of how sweet the engine was running), no smoke, no glitter in the filter, nada. I'm just a stress head with car issues, I hate there being anything at all wrong with my cars, even if its basic. I just immediately get anxious and start thinking about catastrophic failure.
Did the oil analysis include the acceptable range for Lead?
Last one i has said 1ppm is the limit and the engine I was testing had 74, 80 and 33 (was the race car, tested from brand new run in engine). It may not help to tell you the engine didn't last long, but they never did back then :)
They didn't. This is their comments;
Quote
Lead wear rate abnormal. All other wear levels appear satisfactory for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Fuel dilution satisfactory. Viscosity low for specified oil grade. Action: Please confirm oil grade used in this component. Check for lower than typical oil pressure. Check for excessive engine knock at stall speed. As oil and filter(s) already changed, resample at a reduced service interval to monitor and establish wear trend. Note: In the absence of OEM specifications, general severity limits have been applied
I'm not sure why they don't have the OEM specs.
I had a thought. I still haven't confirmed what additive was used but, the oil from this analysis was only 5,000 k's old and I believe was Mobil 1. Given that the oil was good and fresh, would there still be wear in the engine?
What I'm trying to articulate is, I understand that internal wear will happen with incorrect viscosity or not changing oil enough (and maybe other reasons also). But would the wear continue to occur when the oil is changed? Surely it would stop wearing, ie the damage was done? If thats the case, could this suggest maybe that the lead count is not wear?
I dont know if that makes sense. It does in my head.
What has an oil change got to do with whether wear is occurring or not? Wear may be facilitated by oil having been left in too long and broken down - but it is far more likely to be a mechanical issue (ie, pressure).
The thing with the tested oil being only 5000kms old makes it perhaps equally likely to be lead from bearings or lead from the additive.
Ok that makes sense, I was circling around the idea that this kind of wear would only occur with too long intervals between oil changes but I see what you're saying about the cause being something else.
Ok, so I just had a chat with my mechanic. He said there is no real source of lead in the engine, the bearings and pistons are aluminium and the rings I think he said are steel. He doesn't recall what additive he used but that along with the thicker 20w50 he used could be a source of lead.
It's put me at ease a little bit and I guess I'll just have to wait 5000 k's to do another change and see if anything is different.
I appreciate you guys chiming in. I have a habit of immediately thinking worst case with things like this.
You could just drive it normally and change it earlier. Mine has never crossed 2000k's even :banana:
19 hours ago, Duncan said:
well, FWIW mechanic is surely not right about the bearings being aluminium, they would be softer; mostly tin, nickel, copper and lead on a steel shell.
Just after I started to feel better about it all. :(
I'm trying to find more info about the composition of the bearings.
I found these ones; "The Upper and Lower bearing shells are comprised of a lead-free, Silver-based tri-metal material designed for extreme load applications." https://www.turnermotorsport.com/p-3929159-king-n55n54-rod-bearing-set-size-050-oversized/
And ChatGPT said; "The overlay material is often a soft metal alloy such as aluminum or a lead-based material."
I'm just going to send myself mad. I'll just drain and analyse in a few thousand k's.
The good news is, the quote from my mechanic for N53 bearings was relatively low and he’s fortunately an ex-BMW tech. I also went down this path - engine had a low oil pressure error from a missing cage in the filter housing. I ended up watching a million hours of rebuild videos until my oil analysis came back okay other than a shit tonne of boron *iirc* which was consistent with a leaking oil filter housing gasket. I also recall BMW N series bearings having a different material composition to normal.
  • Like 1
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
