I thought about that one, however I don't know if the thread is the same ?
I believe this sensor tells the ECU when the power steering pump is working (especially for iddle)
Looking into r34 gtr and gtt service manual :
- when steering wheel is not turned : 4.6-4.7V meaning switch open
- when it is : 0V meaning switch closed
2 hours ago, bigboss59400 said:
No, by "the other way around", I meant 4.7V likely to correspond to switch closed, rather than open. You don't get voltage back to the control unit when a switch is open. You will definitely measure a voltage at one of the terminals of a switch when it is open, but it doesn't turn up at the other terminal (and hence then on to the ECU in this case) until it is no longer open.
It is for idle up signaling when the power steering is under high load. For example if the car is stopped and you turn the steering wheel all the way to the end of travel. My best guess is the thread is identical but unless you can measure yourself it’s hard to be sure. The R32 switch is generic for Nissan so you might be able to find one in a junkyard or a cheap aftermarket alibaba special just to check fitment. Then buy OEM new for actual road use. I’m unclear on whether the R33/34 need the clearance on the switch hence the special part requirement.
I’m pretty sure 4.7V corresponding to open switch is normal. The ECU can detect it too, voltage can exist in the absence of current flow. When the switch closes as the impedance is very low relative to the voltage source it drops to near 0V which can also be sensed.
Yeah, but that's not normal usage of digital input power to any control system. A switch shorting directly to earth can only pull down the supply side to "zero" volts if there is an extremely high resistance as part of the supply side - effectively a limitation to a tiny current. Otherwise it's a dead short that will just flow as much current as it can.
Normally, as in a PLC digital input card (and indeed, most DIs on most other Nissan ECUs), you will have 12v or 5v available at a terminal on the ECU (or maybe even from elsewhere). That goes out to the switch and only comes back to another terminal on the DI (and this terminal is the actual digital input, the other one is effectively just the supply). With the switch open, no voltage turns up at the DI. With the switch closed, the voltage turns up at the DI. And such inputs are also high impedance to limit current flow to almost nothing. But this is a lot easier to do on the sensing side than it is on the supply side.
I'm quite surprised to see Nissan do what they've done on the R34.
On PLC inputs, yes 95% of the time you're sourcing. In automotive, including Nissan's, 95% of DI's are actually sinking. OP is correct. You sink inputs to GND, thus you will have 0VDC with the switch closed.
Edited by TurboTapin
  • Like 1
There's a lot of things that are weird on the R-chassis wiring/circuit design. Link highlights all the time how parts of the AC control system are always connected to +12V which can cause weird interactions that cause their ECU to brown out and cause no-starts in circumstances that it shouldn't. Nothing obscene, but just a little funny and no longer considered best practice.
Bah! I just went and had a look. Pretty much all of the switches that I would have expected to be externally sourced and sunk at the ECU (on R32, such as TPS, neutral switch, etc) were ECU sourced. And now I have to wonder what sort of drugs the automotive engineering world have been taking.
There's advantages and disadvantages to both. Sourced DI's are used in automotive for reliability (You can't short signal wires) and ease of use (You have chassis GND available to you anywhere).
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
