It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn.
Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing
Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
7 hours ago, Kyer32 said:
so I need a new speedo cable
Nope.
The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head.
To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy.
I had to manually (and delicately) clean the gunk out of my speedo.
1 minute ago, Kyer32 said:
My tyres are 215/45/r17 the 32 is a type m
On 8/1/2025 at 7:21 AM, GTSBoy said:
Nope.
So if anything it’s be the seal speedo drive sorry it’s being awhile since I worked on one of these is the drive connected to the gearbox or behind the cluster
Yep !
Cluster out first.
Dismantle.
Check for oil grease. If oil and grease = clean.
Then check seal at the drive coming from the gearbox.
Seal broken  = change seal.
Doing it the other way around it will again push grease/oil back into the cluster and then your gonna have to do the cluster clean all over again !
On 7/1/2025 at 11:26 PM, GTSBoy said:
I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
On 7/1/2025 at 11:32 PM, niZmO_Man said:
Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
1 minute ago, MBS206 said:
What makes you guess that tyre size specifically?
Just tried researching factory type m spec that’s all I can find
Search for your VIN in gtr-registry.com and see what it left with from factory. There's 4.3:1 and 4.11:1 diff ratios IIRC, can't remember what models had what.
Also could be tyre size, by factory the speedo reads a tad quicker >80 km/h but constantly out be 10 km/h is weird.
Maybe someone wound the odometer back, and accidentally bumped the needle up?
Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine.
The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember.
On 1/12/2025 at 9:44 PM, GTSBoy said:
No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare.
4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11.
4.11 and 4.08 were R33 namual and auto respectively.
The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them. :)
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
