Hi All,
My R33 GTSt has a broken air conditioner condenser, and receiver drier.  Trying to find replacement parts (specifically a new receiver/drier) has been a nightmare.  Is anyone able to point me in the right direction, please?  It doesn't need to be OEM, just fit in the OEM space with the appropriate pressure switch.
Many thanks,
Michael
Thanks Both - that's an option I hadn't thought about at all.  I'm hoping not to have to spend $3k (by time it's regassed and fitted) on the a/c though.
I looked at buying new genuine Nissan stuff and the price wasn’t that different. Key plus with the frenchys kit is that it users much more modern parts. Other option is second hand.
If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once.
For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
1 hour ago, mcfwordsworth said:
Perfect - thanks Joshuaho96!  Will see what I can source.
The Frenchy's kit linked above, will cost you about the same as factory Nissan. The difference with staying factory Nissan is, you'll end up with an inferior AC system.
Where things are NLA new, you can always try Yahoo Auction JP.
I bought 2 C34 stagea compressors and the first one I fitted worked OK, but feels like a real lottery.
Any future failure I would modernise with the Frenchy's kit or similar for sure.
5 minutes ago, GTSBoy said:
I'm just going to recondition one of my R34 compressors. It's not rocket surgery.
Probably OK if you can do it yourself, our local Auto Elec couldn't get a kit for it so couldn't be bothered fixing....
30 minutes ago, joshuaho96 said:
Aren't R33s R134a?
I thought not. R32s certainly weren't. R33s definitely could have been, but I thought they had much the same gear in them as the 32s. I could be wrong.
I had my r32 converted to R143A before I put the Neo motor (and its R34 compressor) into it. So I didn't even really consider the original refrigerant for the 34's compressor. Seeing as the very idea of "conversion" means that it doesn't really matter anyway.
What it would really come down to, in the car in question, is what ports are on the lines and if they are R12 or R143A ports. And the little bit of work required to convert them and clean the system out of the old juice.
Apparently very early R33s had R12, after that they switched to R134a. So if it's all OEM R134a and the parts still exist it might be worth keeping it stock. But from a quick search the condenser is really, really expensive if it's still available. Hard to say which actually ends up cheaper here, if you end up needing a new compressor the FPG kit is probably cheaper.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
