Has anybody had their wheels refurbished? I reckon it's likely bloody expensive. Even a sand blasting quote for my 17s was 200-300 per wheel!
The E39 wheels are basic BMW M Sport (or M Tech at the time.) they have slight rash and some have signs of bad repair in the past on the lips. The main issue is that they've become really off coloured.
I think it will be too much as this is definitely (supposed to be) a budget resto.
I've been looking at others for sale but they all have some minor damage and colour issues.
In the end I think I'll just need to sand blast them myself and do a respray.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/
29 minutes ago, dyl33 said:
I got a quote to restore a set of Volk racing gtc wheels at a wheel restoration shop which involved repainting the centres fixing some small gutter rash and repolishing them and the quote was $2.5k
I ended up getting them sandblasted and powdercoated for $240
Yeah this confirms what I was thinking. Volks are worth a crap load more than my M Sport 17s and 2500 is nuts!
240 is crazy cheap, was this 20 years ago?
I have a fairly good air compressor so I'm tempted to get an eBay sand blaster.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8000752
11 hours ago, GTSBoy said:
Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
I was wondering about this. I'll do some research.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8000763
  • 4 weeks later...
4 minutes ago, Duncan said:
On the bright side they should come back perfect....until the first time you make a mistake parallel parking.....
But, curb rash is easy and relatively cheap to fix.
It's the imperfections on the rest of the wheels that I'd like to see gone. Don't want to spend big money on wheels that are out of production though. I'd be so worried about breaking one afterwards on the offroad-adventure that is Sydney roads these days. :(
Following this topic with interest.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001600
I got a quote to refurbish some BBS look-alikes -best part of 2k.
I had some alloys sand blasted - bad idea, in retrospect. Had to wear gloves to handle them! I had them powder coated to protect the rim.
Rather than sand blasting, I recommend hydro blasting (blasted with micro-fine glass beads carried in a water stream). I had a set of TRX rims done recently for only about $200 total.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001628
Do you have any before and after photos? That's $200 just for the hydro blasting?
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001655
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
