  • Replies 151
  • 1 month later...
I work in Accounts Payable at an international furnishings company *thrilling, really*..
Can't go much further up from where I am, so I'm now looking for a slightly more exciting (& closer to home) job as a PA/secretary or a similiar admin role. I keep suggesting to (always busy) Roy that he needs a PA but he won't have a bar of it ;) BAH!
I always see at least one Skyline on Montague St, Sth Melbourne & a few on Moreland Rd on the way home every night.. (5ish).
I've also done quite a few websites in the past, but unless I can secure a nice, cushy updating role... I'm a bit over it.
Donno, I'll be sure to stalk you and ask what a tennis racquet is for :) (violence? commodore drivers?)
  • 2 months later...
Thought I would bring this topic back to the top again.....
I'm a QF pilot on the 744 and am the proud owner of a 92 GTR R32 !!!!
lol. I'm an air traffic controller and my *cough* 89 model GTR cleared customs two days ago :D
Mark
Recently been taken on permanently in the role I was contracting in. Employed as an IT Manager for a fairly large haulage firm. We cart things all over the eastern sea board of oz so if people do want anything transporting, PM me and I will see what they can do. (reminds me I was supposed to be getting a quote for someone!)
Also run my own business which is Australian Electrics and Entertainment which supplies IT equipment and computer components to the public. Also DVD's and console games and networking equip. PM for that as well if anyone wants anything (Daniel, emailed the guy today and awaiting response)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
