is there an online place where i can check out prices of things like harnesses (no not ur ones denham i want ones that will actually protect me lol), bonnet pins and helmets etc
tried revolution but i couldnt find the prices... i wanna get some bonnet pins... some harnesses and stuff before i get on the track.
LOL, my harness work fine, i might use one at sandown to prove it. Will Scrutiny check for any labels on the harnesses?
  • Replies 409
I didn't think fuel itself will add any more power,  rather with better fuel you can run more advanced timing, compression etc. without encountering detonation.
Its the raising of the detonation threshold, which allows more aggressive timing / boost etc that will give the extra hp.
ie: If your car is tuned to run on pulp and you add a tankful of av or any other fancy brew you will not see an increase in power without altering your tune.
A car like Denham's has Enough Power™ so in a case like his the hotter fuel simply offers better protection to detonation, old fuel, weird load conditions, boost spikes, heat, blah, blah...
If you tune the engine to make the most of the better fuel then you are back to square one as far as "headroom" goes. If you are chasing more power then it is all good though.
sorry i put my life in the hands of FIA approved not YCP (Yum Cha Performance™ )
:D
Ni - sounds stupid but I was told on Sunday by Ron that Autobarn currently have some FIA Approved - dated until 2009 - 3" - 4 point Harness for sale for $399 that looked really good. Can't tell you much else about them however.
LOL... hell i plan on driving around without my seatbelt or harnesses done up.
If i crash i dont want to walk away, actually it woudlnt be a bad way to go. Just remember to try and salvage my semi slicks as someone else might be able to use then in an afternoon session :cheers:
If you lunatics start running $4-8/L fuel then the days will soon get mighty expensive. I one tried VP racing fuel (110 for 20L), made no performance difference without the retune.
It did run cooler and idle way smoother, but stuff all performance difference...but hey knock yoursleves out, actually you will knock the birds out of the trees as you all drive by :)
Fancy fuel or not BRI-58Y is still gonna blow the door off all of you. (I think Nige has put some C4 in the boot :Bang:
Roy - you an add:
benjamin74 and Emre (the 2530 R33 GTR twins) to the list. Its going to be one hell of a skylines presence! lol
Maybe we can hold ou own track days!
Kool thats 11:) If we can get another 4 or 5 cars then this will truly be a trackday of extraordinary magnitude! :D
New SAU - NSW Policy to be applied for all SAU- Vic events, cheaters with 4wd are not allowed to run cheater tyres, unfair traction advantage :flamed:
oooooooooo i was wrong i do get paid bfore then!
hmmmmmmmmm i'll download the form... if i cant get there in the ceffy and we still have the soarer i'll use that :D
Don't panic about the noise - they take the tests from 50m away. Trust me - have you ever heard a full blown 69 Mustang with a 7L Donk go past at full revs? Makes an import sound damn quiet. And there are 2 that race on these days noproblems.
Basically if you have an exhaust you will be right. You won't get done for noise.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
