If there is such a product called spray on silicon i will be try this over the weekend.
Another theory im curious about is; If the silicon is effective in insulating the spark, couldnt you use a bigger gapping as you would have a very strong spark thus more power? The reason being is reducing you gap also reduces power/kw on the dyno.
  • Replies 148
Posted Images
I've actually had a few good tuners tell me that regapping your plugs 'down' to 0.7-0.7mm is actually a work around for bad spark (bad plugs or bad coils). They both said 12psi (stock turbo/ecu) can be obtained by a good set of coils/sparkplugs.
Silcone is a good insulator, but I don't know if it will stick to the particular type of plastic the coil packs are made of.
At the plastic welding place I went to, I asked what alternatives there are to araldite, and he said possibly fibre glass (just the resin, which is also an epoxy), but nothing will stick better than araldite.
Why are you pushing for other alternatives?
In regards to gap, theoretically, yes.... you can increase your gap now for a bigger spark.
well I am going to coat my plugs in a layer of silicon (roof and gutter so it wont react with anything), and see how thats works. that should stop the spark! Iam only pushing for silicon cause araldite doesn't perform well under heat, the glue begins to get soft and sticky again, and may run!
it shouldn't.
if you look at the back of the coil pack (the tallest part), it is sealed off with an epoxy - not much different to araldite. Well this is what I was told when I took them to get plastic welded. I told the dude that temps around the coil get quite hot, and he said it wont be an issue.
Tell is if the silicone sticks, and I was told not many thinks will stick to this type of thermoplastic besides araldite. So there may be a concern of the silicone peeling off after a few weeks or so.
Hi guys,
My R32 GTR was also missing at high revs with above stock boost... I changed my plugs to Iridiums and then the problem became more apparent. I check my coils and there were two that were cracked. I've coated the coils now in "Permatex Ultra Black HI-Temp RTV silicone gasket maker" and it's look like the missing is gone in all but the highest(1.3 bar) boost setting.
I'll let you know if I have any problems.
Cheers,
Brad
My missing has been completely fixed now on both 7 and 12psi. The only problem I have now (which is the same as before the missing started) is that on 12psi it feels flat in the higher rpm's.
  • 1 month later...
I have been having some recent problems with my rb25. It seems to be popping and back firing when acceleration between 4 and 7 rpm. I have changed coil packs, spark plugs, igniter box even the coil pack loom and still no luck.
I thought it could possibly be something to do with my fuelk system as it seem sto feel like fuel cut when it happens. If anyone has come across the same problem could they please e-mail me on, [email protected] as i have done nearly everything and ready to give up.
I have read the previous replys and and not sure where exactly you are putting the epoxy glue on the pack.
Thanks, James
Hi guys I have a full set of brand new splitfire coil packs for sale (cheap) for GTR, R32 or R33.
which give a heaps better performance and stops the 4000-5000 popping dead in it's tracks!
http://www.skylinesaustralia.com/forums/sh...ead.php?t=57340
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
