I am wanting for my r32 to get off the boat, but last night was shattered to see a HSV sedan 260kw version totally smash an r32 gtst in a drag.
The r32 was man, had exhaust, could see front mount, and boost gauge. the HSV also manual but looked stock. They both tried as they both skidded on take off and reved the @##4 out of it.
Should this be happening?
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/
In the RB25DET i have no problems ripping down HSV's with the 285 badges on the sides. They will always get the head start because of our buddy turbo lag but then the main concentration is to keep traction. To beat a HSV your power has to be above 200Kw otherwise you stand no chance.
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1027379
hehe, well they did say "Reason why god created turbo lag, was to give V8s a chance"
:jump:
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1027907
really chris? i thought you were on your L plates? being 17 and all...
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1035103
Thanks for stories and comments lol.
Knew r32 was never going to be racing menace but hey just something about the guys in commos where I'd love to be able to beat them in a 15k car compared to 90k or whatever they are.
Sorry didn't see if r32 driver was p plate driver or not - but sounded like he left second gear on the road - it crunched in pretty hard!
rookie or rich i guess.
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1036310
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
