  • Replies 45
Yeah - I drive a silver R32. I will have to have a look at what speeds I am on other parts of the circuit. The software isn't on this computer.
I run the state series primarily with the occasional national event (Went to Bathurst this year but would never go back. They just give you no track time) I run #31.
thats cool Ryan.. i help out number 42
i have seen your car at every event but couldn't make out who it was!
how was bathurst in the FF - did you have to lift the car at all?
will catch up with at round one next if not on a cruise before hand!
Duncan:
You talking car speed or wheel speed! If you looked at my wheel speed on entry to turn 2 compared to on exit you'd think I had 1000rwkw :flower:
Unofficialy I've run about 1:13 when folowing Daz around, but I wasn't happy with the pads I was running at the time and hope to go quicker on the 1/11. I've also got some half decent road rubber to use this time compared to the junk I was running last time.
hahaha Poakey....try 3rd gear coming out of there instead, wheelspin problem solved, and you don't have to worry about a gear change while coming out of the sweeper :D
New tyres will help heaps...but I think you will find that brakes just slow you down :P
Duncan:
3rd gear just means I need to hit the handbrake earlier and carry more speed into the corner otherwise I bog down on exit and the car straightens out!
fatz:
If borrowing a friends car is instantly worth 10km/h, then I ought to take a hire car for the day. I could blow straight past the 1:10 barrier and aim for some 1:08's!
Not to mention that if we all got the same stock rentals we could have an awesome control class! Any takers?!
Bathurst Was a nightmare. We got treated like crap. The first pratice session we got 4 laps and qualifying we got 5. Race 1 got reduced to 3 laps with one behind the safety car. The 2nd race was only 7 laps with another 2 behind the pace car. Some of the driving was pretty bad - but on the other hand they give young drivers 9 laps to learn a track like Bathurst and dont expect carnage.
If the V8's are running at an event I wouldn't enter. They dont mind taking your money but give you sweet F.A. in return.
We didn't have to lift the car at all. Didn't bottom out anywhere. I will see you at the track sometime
yup mx5 challenge
costs 120 bux for the day
Pete, where can I rent the MX5 from for that much? Do they limit k's (it's a long way to goulburn and back... Plus will they pass you through scrutineering in a rental ok?
R
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
