Works good too, brings it all on heaps earlier, just like the grub screw in the BOV. :thumbsup:
I just got back from tuning after fitting the stock turbo, it was only a temporary tune as Garrett is out of GTX turbo's at the moment. Running ethanol and pushing 1.2 bar the stocker made 225awkw and 850nm. I might just stick with this one for a while... :cheers:
This is a good representation of what a stock turbo (17psi) and a stage 2 (20psi) can do on ethanol, overlaid on the same graph. Cihan was very impressed with the stockers capabilities.
That's very impressive. How long would you expect the stock turbo to last at those pressures? So much has been written about short life expectancy if over 14psi. Is this temporary return to stock a bit of an experiment where you don't care if it lets go Scotty?
I would prefer if it didn't, and I only raised it 2 or 3 psi, should be ok.
I have an opinion on the failures, it seems to be the rear bearing that goes, possibly caused by oil starvation. The oil restrictor banjo bolt only has a 1mm hole and could easily block, especially if the engine internals are dirty. As mine has been flushed, I am hoping it will last just fine. It doesnt sound noisy like they usually do.
It could be a good idea to flush your engines and then check the hole isn't blocked...
I'm not tuning, I'm fabricating a stand for the extraction fan I gave him, the 1m blades should do the job nicely. I wont say what it will suck like... :)
Do you want me to make another modified actuator?
I'd love to know where exactly this is so i could check. Is it on the block or turbo? Is it recommended to drill the hole out to (say) 1.5mm or does that cause other problems?
I'm very keen to make the std turbo last as long as possible and, given your results, it doesn't look like I need to put up with low power. Not saying I will run boost that high though.
It only made 2kw more with the higher boost, but 100nm extra torque.
The restrictor banjo is in the block, you can just get to it with a (17mm?) spanner. Don't strip the thread putting it back in... I dont know if drilling it out will be too much for the seals, probably not, perhaps you should just check it to make sure it is clear.
I think Scott's been drilling the hole to 3mm
Mmmm, 300% increase. Sounds like Scott :thumbsup:
Thanks Scott. You posted at same time. I will check that it is clear in the first instance. Maybe discuss improvements later...
Edited by Commsman
He'll have to answer that one LOL. Banjo bolt...somewhere on the turbo..?.:/
or not...:blush:
For some reason the song "The devil went down to Georgia" springs to mind. But I digress.
scotty,
Nice result with stock turbo, didnt think they would like running at 17-20psi, are they ceramic wheel?
Also your dyno graph doesnt have the power dipo at 3500rpm??? Do you run stock converter/trans?
Yep, ceramic but much different design to the Skyline/C34 wheel, ours run at 1 bar stock where theirs blow at over 12psi apparently. That is where the worry comes from I think as not too many of us have been comfortable with ramping the boost on the stocker.
Nope, My transmission has had a full build, still a work in progress. The 4000 stall dominator made me is a little too open, the factory lockup clutch you see in the dyno graph wont work and just slips as it is trying to haul in 1.5 - 2k revs (which it just cant do). I have disconnected the clutch for street and installed a 12v switch direct to the solenoid for dyno runs. It holds well over 1100nm of torque that way, I had it slipping at 24psi on my old turbo so im not sure where it will crap out with the Garrett GTX.
I am trying to source a spare torque converter to cut open, they are hoping to find as direct a replacement as they can to allow a larger clutch and more efficient stall stator to be fitted. Perhaps the Patrol TC may fit? Let me know if theres a spare M35 one around as this will be an issue for anyone building their box eventually.
So much more power where you can use it on a day to day basis.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
