i've been running BC's for just over a year now and i'm happy with them, i haven't had any issue's. the guys at justjap recommended them to me and said they had a few customers running them in their stagea's and had only good reports about them. from memory the springs are only a bit stiffer than stock, something like 8kg front and 6kg rear. i only have the dampers set to half way and the ride is good. i do a few road trips a year, sometimes with the car fully loaded, and with the exception of a few bumps that would be harsh on any suspension, the ride is comfortable. i've taken the stagea on a couple of twisty mountain runs too and it handled really well.
Thanks Josh i will look into them.
Ok, painful I know for you regulars, however I have skimmed these pages, read other full topics and even searched and I can't seem to find a definitive answer on what springs to use to lower an M35 Axis. Any help would be appreciated.
actually come to think of it, there is a full set of nismo suspension for sale if youre interested
Do tell please?
Also, suspension wise is the ARX different from the axis?
As for coil overs, that would be overkill for me, and if I do that the bug will bite.
http://cgi.ebay.com....3#ht_7846wt_907
should i or shouldnt i?
If they are the ones in the photo they won't fit your car because of the forked ends on the rear unless you have a 260 or one other model I think 2wd manual.
If your suspension is bog standard a heavier rear sway bar will give you the most improvement for your dollar. Then get some second hand Bilsteins retaining your stock springs.
Can someone with BCs tell me if they can be set to standard height? For what I do I really dont want to lower the car...
Easily. I actually think you could set them slightly higher than standard.
I'm just wondering if it would be possible to just get the standard springs in a RS4S "squashed" at a spring manufacturer to lower it? I've had it done before on a couple of my cars (HQ Premier and a VQ Statesman) and it worked fine. I don't go racing around the countryside like a Targa Tasmania driver or anything, I just want it to sit nice. I'm looking to go down 40mm front and 30mm rear. I realize I may need a shorter throw shock to keep the spring captive when going down those numbers. It's just been a cost effective solution in the past (about $40 per spring) and i've not seen anyone talk about it on here at all. Probably because everyone is after super handling. I'm not, I just drive it around but want to look nice while doing it. Some feedback would be great.
Thanks
Ben.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
