he said for his RS4S so its a manual mate.
from what i found looking im not sure if BC's make a coilover kit for the manual stagea. i have stagea specific HSD coilovers (very high spring rates) for my RS4S. if you cant find them for RS4-S(WGNC34) try looking for ones to suit 260RS autech as they share the same suspension.
user "Verms" on here has some TEIN coilovers to suit RS4S/260RS for sale if you PM him for a price. TEINs are good because of the ability to rebuild/service them.
  • 1 month later...
Hi guys you'll have to excuse this as a first post
I have some unknown lowering springs fitted to my Series one rs4 but the shocks are not up to the job , can anyone recommend a suitable shock , I was thinking KYB but having read this thread not so sure now , what is available and proven? I am looking for comfort and good damping
here is a pick to illustrate ride height btw I am in the UK
Nice car! +1 for Bilsteins. I see some mods have been done already - clear indicators, R34 GTR rims? Have you got upgraded rear sway bar? One of the biggest value improvements available - check the group buy here v what you can source in the UK.
I would not highly reccomend KYB's my mate had some in his mazda 323 the old school rear wheel drive bad boy and they lasted less then a year b4 they seemd to get really bad and bottomed out allot.. i dunno personal experience or something but i will never buy that brand.. sorry to be bearer of bad news but cheap usually means cheap... and for suspension that means not long life span..
P.S. my M35 has nismo suspension in it well springs anyways is this a factory spek thing? anyone know if the struts would be nismo or just springs..
Edited by Nismo4Life
If Z33/V35 coilovers fit M35's, does it mean that Z33/V35 lowering springs will fit intoi M35 standard shocks?
They'll fit but it'll be no good; theyre not designed for the weight.
Sold as a set; youd likely have nismo struts :thumbsup:
  • 4 weeks later...
Yes they have definately been discontinued
They were available for a while under a different part number but sadly both are now finished.
I have an account with bilstein and bought the last three sets for stageas in the uk.
I have also been told there are no plans to reintroduce them at a later date.
  • 5 weeks later...
i just put some BC coilovers in my rs4 s1 and i was pretty dissapointed with the ride height, i wound the front ones down as low as possible and no pre-load on the spring and still have about 1.5" of clearence between the guard and tyre, anyone else have this problem?
Silly question, but did they send you the right ones? On my M35 the BC's had to wound almost all the way in the other direction or else the wheel was up inside the guard. Definetly no issue with not enough low.
I remember "Run-it Hard" saying that they didn't go low enough on his Stagea; not sure what he did to correct it, because he certainly had it low in the end.
Might've gone shorter springs?
I don't suppose you actually did wind the the lower section down as low as possible? You need to wind it up to make it shorter...
  • 1 month later...
anyone else got or have seen a stagea with HKS hypermax III Sport coilovers??? i can find a stagea listing, but my newly imported RS4S has a set of these all round.
hey mate.. preety sure my 2000 rs4s has them all round too.. dont know exact model but they are hks and full adjustiable
Edited by shotpointblank
are they gold?? i swear by hks suspension, HKS hypermaxx II are purple in colour- never seen them in a stagea, i have them in my R33, HKS hypermax III road coilovers are silver, HKS Hypermax III Sport are gold in colour and are for track/competition.
http://www.hksusa.com/info/?id=3409
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
