he said for his RS4S so its a manual mate.
from what i found looking im not sure if BC's make a coilover kit for the manual stagea. i have stagea specific HSD coilovers (very high spring rates) for my RS4S. if you cant find them for RS4-S(WGNC34) try looking for ones to suit 260RS autech as they share the same suspension.
user "Verms" on here has some TEIN coilovers to suit RS4S/260RS for sale if you PM him for a price. TEINs are good because of the ability to rebuild/service them.
  • 1 month later...
Hi guys you'll have to excuse this as a first post
I have some unknown lowering springs fitted to my Series one rs4 but the shocks are not up to the job , can anyone recommend a suitable shock , I was thinking KYB but having read this thread not so sure now , what is available and proven? I am looking for comfort and good damping
here is a pick to illustrate ride height btw I am in the UK
Nice car! +1 for Bilsteins. I see some mods have been done already - clear indicators, R34 GTR rims? Have you got upgraded rear sway bar? One of the biggest value improvements available - check the group buy here v what you can source in the UK.
I would not highly reccomend KYB's my mate had some in his mazda 323 the old school rear wheel drive bad boy and they lasted less then a year b4 they seemd to get really bad and bottomed out allot.. i dunno personal experience or something but i will never buy that brand.. sorry to be bearer of bad news but cheap usually means cheap... and for suspension that means not long life span..
P.S. my M35 has nismo suspension in it well springs anyways is this a factory spek thing? anyone know if the struts would be nismo or just springs..
Edited by Nismo4Life
If Z33/V35 coilovers fit M35's, does it mean that Z33/V35 lowering springs will fit intoi M35 standard shocks?
They'll fit but it'll be no good; theyre not designed for the weight.
Sold as a set; youd likely have nismo struts :thumbsup:
  • 4 weeks later...
Yes they have definately been discontinued
They were available for a while under a different part number but sadly both are now finished.
I have an account with bilstein and bought the last three sets for stageas in the uk.
I have also been told there are no plans to reintroduce them at a later date.
  • 5 weeks later...
i just put some BC coilovers in my rs4 s1 and i was pretty dissapointed with the ride height, i wound the front ones down as low as possible and no pre-load on the spring and still have about 1.5" of clearence between the guard and tyre, anyone else have this problem?
Silly question, but did they send you the right ones? On my M35 the BC's had to wound almost all the way in the other direction or else the wheel was up inside the guard. Definetly no issue with not enough low.
I remember "Run-it Hard" saying that they didn't go low enough on his Stagea; not sure what he did to correct it, because he certainly had it low in the end.
Might've gone shorter springs?
I don't suppose you actually did wind the the lower section down as low as possible? You need to wind it up to make it shorter...
  • 1 month later...
anyone else got or have seen a stagea with HKS hypermax III Sport coilovers??? i can find a stagea listing, but my newly imported RS4S has a set of these all round.
hey mate.. preety sure my 2000 rs4s has them all round too.. dont know exact model but they are hks and full adjustiable
Edited by shotpointblank
are they gold?? i swear by hks suspension, HKS hypermaxx II are purple in colour- never seen them in a stagea, i have them in my R33, HKS hypermax III road coilovers are silver, HKS Hypermax III Sport are gold in colour and are for track/competition.
http://www.hksusa.com/info/?id=3409
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
