A lot of info about older model stageas but what suspension is the same as a 2002 M35 Stagea? Looking at getting an airbag setup and it's looking impossible to find anything.
I haven't heard of anyone bagging a stagea. There won't be any off the shelf kits but it wouldn't be hard to put a kit togeather. Just hit up a company that supplies and fits and get them to measure everything up.
Almost all the m35 guys just go coil overs cause there is off the shelf options and price really is pretty damn good. $1250ish for brand new bc coil overs.
  • Like 1
I've heard you can buy kits from japan but I haven't personally seen any. I was thinking that some of the infinity models might match up and I'd be able to drop a set of bags right in without going custom and spending a fortune. I was thinking coilovers but for the look I want bags are gonna be better suited. Looks like I'll be going with a custom setup by the looks of it though.
I have installe dags in a few cars back in the days when they were super popular. there won't be much custom work required to fit bags unless you are wanting it to lay rail over big wheels, which yeah is ALOT of work haha.
really all it will need is a set of Strut style bags for the front and they you may be lucky enough to get a bold in bag for the rear otherwise it will be just couple of plates welded in the rear where the current springs sit. You shouldn't need any cutting etc.
Thanks for the help. I'm gonna talk to a few airbag shops to find out what I'm gonna need for my application. It has to lay about 2-3cm of the ground so hopefully there's something out there.
What size wheels do you plan on running? where you might be limited and where it may cost lots is if you need to modify your inner guards.
I haven't figured out 100% what size but I'm looking at 19x11.5 +8 rear and 19x10 +5 front. Will need to run camber and have abit of guard work done.
So I bought an MV35 from interstate and need to raise it to pass rwc here in Victoria. It has BC BR's however the back is already wound out all the way, so I'm guessing it has the 62.97.255.008 springs like the set I had bought for the old car. What I want to know is what height / part number springs do I need to be able to achieve standard height?
  • 4 weeks later...
  • 1 month later...
Does anyone know how to get in contact with sk? I would like to buy some bilstein's with the grooves cut or has someone else taken over what he was doing. I have read up to page 20 but then it kinda goes on repeat
I have 3 that I pulled out (1 of them blew up) with eibach springs in them free to good home but pick up only from maroubra.
Edited by stock stagea
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
