spotted a pearl white s2 yesterday afternoon with a dolphin bodykit and what looked like 19'' dished rims, looked absolutely stunning
was outside the moore park super centre on todman ave in kensington.
I didnt spot this (still havent seen a stagea) but a mate spotted a and took a photo of a white S1 on the sunshine coast, QLD. Was chock full of gear in the back (looked like they were moving house apparently) and being driven by a pair of 45+ year olds.
spotted a pearl white/cream stag with a autech kit?maybe???dished rims,nice car,anyone here??? on the graham farmer and then through tunnel,sounded nice,quieter than mine though(half good/half bad :P )had some car audio sticker on back window,i go everywhere an i dont think mine has been spotted...mines the silver one(stock now i got rid of rims) with the fmic and loud as exhaust....usually goin between half and flat foot :)
spotted a white S2, pulling a trailer on fwy sth at about 7:30m this morning, trailer said "balducci painting" i think?
then a white 260RS (or atleast the top of a white stagea, with a 260RS wing, pass me on the other side of the concrete bollards on roe hwy at about 7pm tonight.
nothing like mate. couple of hundred will have it modified to fit though
thanks anyway damn lol.
if anyone has a hks or similar zorst to suit s2 stagea cat back pm me i have cash waiting. canon out back look i want.
Edited by MARKRX3
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
