there is a meet planned for sunday 4th may... be there!
16 posts in 4 years????? dude!
bobby not everyone is a forum whore like yourself :ermm:
spotted green s1 on Beaudesert Rd, Acacia Ridge heading towards the city. had to smash abit of traffic to get beside and wave :ermm:. Its funny living in "THE RIDGE" so many confused bogan looks :dry:
a ha!! So it was your stagea l saw down in my carpark!! (i say mine as a few of us pretty much own a section of it!! haha)
Looks good dude ... l want your sunroof's though!
can say the same about your car ;)
Where do you work at chady? PM me if you prefer. :pwned:
indeed...was dropping by Hills Motorsport to grab a window for the 350z (thanks to the guys that smashed that to steal......nothing)
what were you driving jeffboyracer, didn't see another stagea?
Spotted: in an electronics store carpark, somewhere near Adelaide... silver S2 with Dayz kit :D
I arrived in my white S2, nobody else there carpark was empty, go inside, come back out and there's this silver S2 parked next to me. Did a double-take and it was like 'hey, snap!' Have a pic' will add soon...
Spotted: Today 3.50pm Gold Coast, leaving the spit, turning North onto the Sundale bridge:Dark green S1 - Thought it was Hugh (66yostagea), but closer examination revealed it had a full shirt kit with no wing, and Volk wheels with polished rims and gold centres. Would have beeped and waved, but I was in the Chaser... Plate was something like: 630JPU.
Never seen another dark green. (Fark, that rhymes)
I think performance-wise has a dark green s1 too, Hugh. That makes "maybe" two in NSW including mine, but a friend told me he saw another the other day near his place in Blacktown, and it wasn't me.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
