Been spotting various Stageas around Adeliade, must be the Stagea capital or there just more active than Melbourne.
No no defiantly correct with that stament we have heaps of stags in Adelaide. When i brought mine just under a year ago hardly any. Now im seeing a couple a week.
Yeah no shit.. last time i was over here i was lucky to see one.. I just sold mine and could count on one hand how many other Stagea's id seen in Melbourne.. Adelaide is crazy with Stagea's.. seen atleast another 2 today!
Edited by SHIZNT
Spotted sunday after lunch a white m35 stag on general holmes drive westbound, was stock apart from rims and exhaust, unfortunently i was in my mates ford focus and not my stag.
can everyone keep an eye out for my yellow s2 rs4s with dayz kit (and carbon bottom middle bit) on the gold coast
letting the gf drive it while im away cos her car is dieing slowly
let me knwo if you see her and what her driving is like
thanks
Tom
thanks
Tom
LMFAO :blink: WILL DO
I spotted a white C34 (I *think* it was an s2) heading North (towards Hornsby) on Pennant Hills Road around Thornleigh at around 12.15am tonight. I was in my dark green s1 heading the other way, on the way home from the usual Thursday ritual of heading up to the Central Coast.
God dammit.
Are you Brisbane drivers blind?
I'll be spotted eventually -.-
:laugh:
Don't worry mate, you'll be spotted eventually.
It took nearly 2.5 years for me to be spotted in this thread and even then my stag was referred to as silver!
Never mind that for 1 year, I was the only M35 in the damn state!!!... I guess I must have been mistaken for a pearl blue Volvo :D
:blink:
Never mind that for 1 year, I was the only M35 in the damn state!!!... I guess I must have been mistaken for a pearl blue Volvo :down:
Have you seen another stagea mate? Perhaps you are blind as well. lol :)
I'm impatient though :huh:
I guess to be fair, I've only ever spotted one so it makes sense that no one has spotted me.
if you come up the sunshine coast,there are only two m35s, my dark blue rx and one burgundy arx.There are quite few other stageas, but they arent all on this site. :) .
Three. I live on the coast (mapleton)! I just mentioned Brisbane as I've been doing a ton of driving in Brisso lately.
Never seen you, but I've seen the burgundy arx. They didn't wave back to me :huh: I saw them out in Kawana.
I'm up in the hinterland but do cross over into kawana a few times a week (work) and to the beach (maroochydore) once a fortnight or so.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
