Spotted S1 RS4, (anyone on here?). Grey job with bar style grill Hannan street intersection turning right into Boulder rd at around 2pm today. Waved, honked, I was in the troopie heading up Maritana st. Tried to get rego ~ "CNW____" but lites green, traffic & stuff, + craft. Beer run.
Cheers GW
woot, first time spotted in the stagea, and i only had to drive to the coast lol.
Zoomed past me whilst on lunch at aussie fair. Spewing I missed the spit!
Also met Pyro and Cheddar last night, Thanks for the bits and take care on the way to SA.
Today I saw Pipster in Burleigh
Then another yellow S2 on the M1 with black wheels.
I saw a green S1 that I see all the time parked on Ashmore Road just near Ashmore Seafood and Steak. Anyone here?
Spotted a silver S1 RS4 on the southwest highway this morning on my home from night shift, then a white S1 RS4 this arvo at the local shops on my way to work, funny as there every where there everywhere.
Spotted!!!
White S2 RS four, corner of Johnston st and hoddle st Abbotsford 6:30pm
great looking car, Thank you very much for letting me into the traffic as well!
Gave thumbs up, take it easy buddy if your on here.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
