spotted two today, a silver m35 on annangrove road, and then a white m35 on new line road in dural, that one had roof racks....
That was my wife in the silver one. You were spotted too! I heard about the offset numberplate when I got home.
Oh yeh ive seen it quite a few times i think, normally further up closer to the windor road end....
and had to move the numberplate so it doesnt get in the way of intercooler goodness!
That's my mates car... quite a bit done to it (none of it his doing though lol)
Doesn't get on here? Why havent I seen this mystery blue car till now?
About time for a eastside m35 cruise, think you could help me organise one? I need some good cruise pics for my background. :rofl:
About time for a eastside m35 cruise, think you could help me organise one? I need some good cruise pics for my background. :P
Nah, he's not on SAU.
Cruise? Maybe... will need to get a couple of things done first. :rofl:
Will talk to you about it soon.... should be able to get some reasonable numbers
Edited by iamhe77
Cruise? Maybe... will need to get a couple of things done first. :P
Does this mean I will need to clean the outside of my car for the first time... I've been cultivating the dirt on the back windows to increase the Privacy glass effect... :rofl:
Spotted a white c34 heading back from wynum... you know on the unlit bendy road.. i was trying to tailgate you in a white astra and yelled stagea a few times. rego had the number 5 in it.. perhaps 571 xxx or something. cannt remeber. Turned right on to wynum road at the traffic lights..
About time for a eastside m35 cruise, think you could help me organise one? I need some good cruise pics for my background. :blush:
any room for C34s? :P
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
